Question about Baby Lock Ellure
Thread is knotting up
A noise comes from the bobbin case when I am monogramming and then the thread knots up on the back side of the material. Also the thread seems to strip thin when this happens.
  • 24 Answers
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
Posted on Aug 13, 2008
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
How to set the tension
The carrier and bobbin are removed. Place the thread in the carrier with the thread dispensing counterclockwise. Place the thread between the metal pieces (tension). let the carrier hang from your finger and bob it slightly. It should extend one inch. If it doesn't then you can adjust it by turning the small screw slightly until it does what I said. Now, replace this assembly. The top tension you can start at three. The sewing should be an even pull between the upper and lower thread. If the thread knot is in the center of the material it is right. If the knot is under the material then raise the upper tension. If the knot is on the upper material then you should lower the upper tension. The key is to start with the bobbin tension correct and adjust the upper tension until the knot is in the center of the fabric
Oct 26, 2014 | Sewing Machines
Somethings wrong with the bobbin, it knots up on the back of material
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 15, 2013 | Singer 3116 Simple
Upper thread gets jammed in bobbin area
Dec 12, 2012 | Brother Sewing Machines
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
I am having a problem with the thread knotting up on the bottom of my material. The needle starts to lock up and when I start checking the thread is all knotted up. I then take the bobbin out and it...
What you have going on is probably a bobbin problem. The knots are referred to as birds' nests and happen usually happen when your bobbin thread gets caught on something in the bobbin area. To be certain it's a bobbin problem, change your needle. Even if the needle looks fine, it could be just slightly bent and still look fine to the naked eye. If that doesn't solve the problem, take the fabric out of the sewing machine and turn the machine wheel by hand. Watch what happens thru the plastic window in the bobbin area, or if you don't have a plastic window leave the bobbin covering off. Is the thread catching somewhere and causing a bunch of thread to gather in the bobbin area? Be very careful when investigating in the bobbin casing/area-it's easy to chip things in there! Often times, a piece of something falls in there and can be pulled out with tweezers. Just as often, the bobbin casing is slightly tilted and needs to be straightened or has a chip in it and needs to be replaced. You can normally get a replacement on eBay, searching with your machine model number. Also, check out SewVacUSA. If you need help replacing the bobbin casing (it's easy, you just need to be careful), or if these solutions don't work, leave me a comment. I check back daily, so I'll get back to you within 24 hours normally. Leave me as much detail as possible and I'll do everything I can to help you!
May 11, 2011 | Singer 3116 Simple
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Bobbin continues to pose problem - knotting thread underside of fabric,
In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
USE GOOD THREAD!
Thanks,
Bonnie
Oct 25, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
230 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
