About filter and fuse
Where is the air filter located at on my 52 in zenith dlp tv. also i take the fuse out and it look clear on one end and cloudy on the other end but the filament is still connect inside fuse
  • 8,617 Answers
Did you see my last post on the air filter? Check the fuse for continuity with an ohms meter.
Posted on Mar 13, 2008
I have a 2005 zenith 52 inch model# Z52SZ80 heres the problem i replaced the lamp and when you turn it on as soon as the picture comes up the lamp shuts off and the red lamp light blinks 8 times then...
This is a DLP tv wright?Problems with many DLP tvs after changing the tv projection lamp,tvs still have the same problems or make alots of cliking sound too.The board that call the Ballast baord is also is dead.The Ballast board only job is to ignite the tv projection lamp.
Mar 01, 2011 | Zenith Televison & Video
I need the Service Manual fo Zenith DLP Projection TV model #Z56DCd1D so I can replace the Lamp.
No service manual out there,the tv corporations don't release them to the public only to their authorize serviced center.Try website YOUTUBE.com have video tutoring u how to do it.
Jan 14, 2011 | LG RU-52SZ51D 52" Rear Projection...
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
Mar 06, 2010 | Zenith D52WLCD 52" Rear Projection...
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up...
maybe the original filter was dirty or the background of your tv was dirty and the new filter clean up the background sometimes this types of things happen so im glad that you tv works ok but in further if you need parts you can go to http://www.discount-merchant.com/
regards neurot
Dec 18, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
About 52 in zenith tv fan
If the air filter needs cleaning The fan will stay on for an extended time to cool the light engine. Try cleaning the air filter that should solve your problem
Mar 11, 2008 | Televison & Video
About tv shutting off
Yes I believe your problem lies with the air filter needing to be cleaned as the fan will run an extended time to cool the light engine if the filter needs service.
Futher help on 52 zenith tv
What is the model number? If its a DLP it could be thermal due to the air filter. If its a CRT projection it could be a bad capacitor that loses tolerance as it warms up. Need the model number to actually be more accurate.
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
