Question about Car Audio & Video
Alpine Cdm- 7834 wiring help
Need to hook up to a 89 ford tempo with a factory amp that only has 5 wire speaker input. alpine has 8 speaker wires. how do i combine the negative speaker wires to hook up to the factory amp?
Bypass amp and run new wires to all speakers ,,,, will sound better .
Posted on Jun 17, 2008
Just use any negative wire you only need one wire from the negetive.
Posted on Apr 13, 2008
Where is the serial number on my alpine Cdm -7834
Usually on a paper label or stamped in the metal casing
Jun 13, 2010 | Alpine CDM-7834
Hooked up speakers(subwoofers) but i can only hear them wen the (radio mode) is on, not cd mode
You hooked up the wrong blue wire. There should be two, one for the power antenna and one for the amplifier turn on. Use the other one, as you have the power antenna wire hooked to your amp. That wire is only active when you are listening to the radio, not using the CD player or any other aux input if you have any. Common beginner mistake, it's happened to us all.
Feb 16, 2010 | Alpine CDM-7874 CD Player
Alpine CDM-9821 CD Player
an easy way would b 4 u 2 gent an fm tramsmitter thats the cheap route if its not on output 4 an ipod connection im pretty sure u can hook up ur amp the only wires that need 2 com from th in-das is a remote and ur rca the remote wire should b blue n u can get a headphone converter with rca ends but i doubt ur ipod will play out of ur amp.... let me know if this helps
Jun 23, 2009 | Alpine CDM-9821 CD Player
WIRING ALPINE CDM-7874
I need a wiring harness that plugs into the back of alpine cd player cdm-7874 & a user manuel
Sep 25, 2008 | Alpine Car Audio & Video
I have an Alpine Model CDM-9821. I just bought another vehicle and want to install my alpine in it. I have all of the wiring hooked up properly but am unable to get my unit to power up. I have 12.5...
did you use an installation harness? you should have the following when you test-
red wire-12v only with key on
yellow wire-12v at all times
reverse your test light to check the ground wire should be 12v with test light hooked to pos
Jun 20, 2008 | Alpine Car Audio & Video
Alpine CDM-7833
what wirers are for power
Jan 13, 2008 | Alpine CDM-7833
No backlight on a cdm-7834
The only possible installation problem could be the illumination wire on the head unit. If this is hooked to a 12 lead it would dim the backlight. Try disconnecting the orange wire if it has one(I'm not sure if the 7834 had a dimmer lead). If that doesn't fix it the head unit will have to be serviced.
Sep 03, 2007 | Alpine CDM-7834
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Cdm alpine 7861
Make Sure the remote wire is connected from the radio to the amp, its normally a blue wire. Here is a picture of what the setup should look like.
Jul 27, 2007 | Alpine CDM-7861 CD Player
Car Audio & Video Logo
302 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
