Question about Vacuums
My Miele vacuum carpet head will not work. It is an SEB236 Powerbrush and the "reset" light is on when I turn on the vacuum. I don't know what this means! Please help!!
    New Friend:
My Miele vacuum carpet head - miele-vacuum-carpet-head-x1tp2f0puxzo1oschftysm5p-4-0.png
Posted on Jul 26, 2015
    President:
  • 1,673 Answers
If the light is on then you must be getting power to the power head. Could be a motor problem, there is a push button switch and a circuit board. Just have to checked to find the problem.
Posted on Mar 13, 2008
Is it possible to vacume water with the miele slaris turbo plus?
I wouldn\'t attempt that unless it says you can do that in the manual. Use a steam cleaner. They are made to suck up water.
May 18, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Miele model SEB217-3 beater bar stooped working
Check the switch .It usually have a wiring diagram
Jan 25, 2018 | Miele Vacuums
MIELE Silver moon turns off after about 10 minutes of using. If I press the "+" button on the handle, it'll turn on again and start up again. Is this an overheat thing or a hose thing?
That sounds like a hose issue, but to make sure it's not an overheat issue I would recommend ensuring that the hose, wand, and dirt tube through the power-head are all clear and free of obstruction. Also try raising the height adjust on your power head: if you have it set too low, air can't move through the carpeting and therefore it will overheat the motor and also not clean as effectively as it could. If all of these things check out, you will have to replace the hose with an SES-125A, but once you've done this you will not have the issue again. Cheers! -R
Aug 03, 2011 | Miele s558 Silver Moon Vacuum
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
Need drawing to reassemble power head
I have attached the parts drawing of the power nozzle that came with the Red Velvet model, or the SEB236. Unfortunately the way that it's posted online, it's done in a way that makes saving the picture and posting the picture here in the repair more difficult because the pictures are larger then the 150k that Fixya allows. I went ahead and uploaded this pictures to our site, and left the 2 links below in this repair.
Powerbrush Picture:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-red-velvet-power-nozzle-seb236-1.gif
Inner Casing & Light System Picture:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-red-velvet-power-nozzle-seb236-2.gif
If you need help on getting it back together, please feel free to use the Clarification Request form here on the Fixya repair page with the part that you're having problems with, and I'll be more then happy to help you.
If this information helped you, please be so kind as to rate my solution as helpful by clicking the 4 Thumbs up icons in the top corner, this is what keeps Fixya repair experts coming back and giving free repair advice.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Miele S558 Red Velvet Bagged Canister...
Miele SEB-213 powerbrush stopped working
Pull the head cover off to check the belt, if the belt is ok then it might be the power connection between the handle and the power head shaft. If the red light is on the power head, then its not the connection
because its getting power. Now some heads have a reset button on them,you could check this also.
With the cover off the power head, remove the belt, now turn it on, and be careful, but try to make the motor shaft spin,with one finger, because if it does start to spin you do not want to hurt your finger.
If the motor starts to spin,put the belt back on, if it does not spin again, the motor is too weak.
If it does not spin at all, the motor is bad.Hope this helps you,and you get it working.
Mar 24, 2009 | Miele SEB 213-2 Vacuum
How to change the belt on a bissell powerbrush deep carpet cleaner.model 1694
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Mar 10, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
Miele Service Manual
where can I get a copy of a Miele S 230 i cannister vacuum service manual and model # of the right dustbag. Thank you.
Mar 06, 2008 | Vacuums
Vacuums Logo
1,047 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
