I have a Siemans NCDC 2015 car radio that switches itself on at any time. No problem if it is whilst driving but a drain on the battery when parked or over night.
  • 1 more comment
  • tgarbet_889 Mar 13, 2008
    The Siemans NCDC 2015 is a Radio/CD player/Sat nav/Telephone unit and quite complicated in 4 units. Radio/control- CD stack and player- screen- and Nokia telephone unit.The units on/off switch is on the main-Rado CD unit (2 units strapped together)
    The units are factory fitted to the existing wiring loom. The radio normaly works omly when the ignition is switched on but can work when switced on with no key in , then it is designed to switch off after 1 hour.
    The ignition switch has been changed and the car electrics checked out by an auto electrician. the fault is reported to be in the radio unit!
  • tgarbet_889 Mar 14, 2008
    I have Emailed this site. Thanks for the link.
    Master:
  • 788 Answers
Check this site out: http://home.btconnect.com/nickargue/OmegaSatNav.htm The guy seems pretty knowlegeable on the 2015. May be worth emailing him. I can't find the information you are looking for but he may be able to help you.
Posted on Mar 13, 2008
  • Dean Joly
    Dean Joly Mar 13, 2008
    You could also purchase a new head unit on eBay and swap it. The head unit and Graphical display do need to be de-paired before they will work with another unit. A tech2 technician is needed for that.
  • Dean Joly
    Dean Joly Mar 14, 2008
    Don't forget to rate my suggestion. Thanks. Let us know when you figure out.
    Master:
  • 377 Answers
A wrong electrical layout must be consider. The connection of all devices and apparatus on your is only directed into one line..
Which is the line/wire were connected also directly connected to the car battery. By that your car batt can possibly drain, coz of the four device connected and sharing into one line...
Go to the auto shop and get help fix it my an auto electrcian expert.
Thanks,
  • 552 Answers
Http://www.fulldownloads.us/free-full-download-opel+siemens+ncdc+navteq+-crack-serial-keygen-torrent.html
Try this link which has a free full download for it and also some help.
Please let me know what happened so we can brainstorm somemore if necessary.
Thanks
  • Hjalmer Lamminen
    Hjalmer Lamminen Mar 14, 2008
    Just wondering if you solved the problem you were having.
    Regards,
    yalmer
    Guru:
  • 1,894 Answers
This may be due to some shorting of the circuits in power board
  • dewan nafees ahmed Mar 13, 2008
    else its just a loose wire that makes this action
    can correct it by disassembling the setup and looking for the place to correct
    thank you sir
    good luck
    dont forget to rate the solution
    wow...great and polished reply s..
    noting different from what i told you sir
    thank you
Radio stays on drain battery when parked 1999 lincoln nav
If the only issue with the radio is that it will not turn off and then drain your battery, I would locate the power wire to it and put an on/off switch on it to manually do the deed . Repair not cost effective. Make sure it is the radio responsible for the drain. Use an ammeter to check power usage with ignition off and radio connected and disconnected to just make sure.
Sep 19, 2017 | Lincoln Cars & Trucks
Hi i have 2015 gsx 1250 fa ride it to work and back about 30 km, took a 140 km drive and parked after 4 hrs bike was dead not enough power to start. Jump start it and it is starting now Steven.
Check for parisitic drain of battery. Turn of key and accessories. Disconnect battery ground and connect test light between battery ground and disconnected wire. If test light illuminates you have parisitic drain. Remove fuses one at a time, when light goes out you have found the faulty circuit.
Nov 15, 2015 | Power Motorcycles
Jeep liberty 2007 clock and radio stays on drains battery
Ignition switch may be worn out or the safety switch on the transmission linkage when it is put in park may be bad ,
Aug 12, 2014 | 2007 Jeep Liberty Limited
Why would my My Car Radio in my Hyundai Getz SXI switched itself off whilst I was driving
Check the fuse. There should be a fuse for the radio, either in line or in the fuse box.
Aug 08, 2014 | XM Radio (XMP6000)
My 2007 Chevy silverado battery keeps draining. I thought it was from the radio not shutting off when I open the door but I shut the radio off and the battery still drains. What can be draining it?
The battery itself may have an issue? You could try disconnecting the cable when you park and see if something is truly draining the battery. If it is you may notice a slight spark when you disconnect the cable. The alt may have a bad diode so it will charge the battery but drain it once the motor is shut off? Or it could be something like you suggested. The radio remembers its settings by being connected all the time. However a stock radio does not take much from the battery.
May 09, 2014 | 2007 Chevrolet Silverado 1500 2WD
How can I tell if battery is bad or a short draining battery
Take the battery to an auto store. They have an amp meter to test it with. Check for poor connections at the back of the radio. If it's wired to a hot lead and not the ignition ( key on) or aux, my old cd player would turn itself on and run down the battery while parked. For me, bad radio.
Jan 04, 2013 | 2001 Chevrolet Astro
Is there a parasitic drain on my battery, my radio comes on by itself when i turn the ignition switch sometimes
Have to put an amp meter is series with either
battery cable & start pulling fuses to find the
offending circuit
There is You Tube Video you can watch on that
Dec 27, 2012 | 2002 Suzuki Vitara
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Siemans NCDC 2015 Car Radio/Sat Nav/Telephone/ CD player
Heres a question....does the main power switch "feel" like the others.
The main power switch is one of those that gets a workout. After looking at some images, I am going to guess that it is what is called a "Tac" ( short for tactile ) switch.
How do you tell if it feels right?.....go to the least used switch on the unit ( is should theoretically be like new if it is the least used ) ,and very slowly push it in. What do you feel?....some resistance and then it gives?.....do you hear a slight snap ( make sure the unit is off or the volume is all the way down ). Now go to the power switch....does it feel the same ? A sign that ths switch is finished is that there is no travel to it, that is, when you push is it stops immediately....the least used switch should have a little "room" in it before it hits bottom and makes the connection.....I'll bet the switch is shot.......give it a go......Thanks..Rob
If you can feel a big difference in the switches, then I would take it to a local electronics shop and see it they can replace the switch ( those type of tac switches are EVERYWHERE ), or maybe find a seimens shop and have them look at it.....better than 1500 !!!!
Mar 13, 2008 | Audio Players & Recorders
148 people viewed this question
 Grubhead
Grubhead
