At the bottom of the water tank there is a valve which is consist from a spring and plastic tab with "O" ring.
This valve and where is match with the base on the machine is dirty or full of scale or even bend or damage so as soon as you place the water tank back to the machine this valve does not fit excactly on the base threfore is leaking all over the machine.
First I sugest before you place the tank in place to inspect it over the sing press it with your finger and try to see there is something wrong as I mention above.
Then make a visual insect on the machine where the valve shoult fit.
Good luck
There are many possible points that the leak can be.
Most posible is from water tank to the pressure pump then connected together with plastic pipes which they brake or loose.
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
