Question about Dishwashers
Please help We turn the machine on and error #304 pops up. The units almost up toTemperature but doesn't quite make it. A day or two before this washappening error #203 had popped up a couple times. The operationsmanual states the reasons for some other errors but not these.
    Problem Solver:
  • 11 Answers
Hi, you dont state the make and model of your machine.
Posted on Nov 11, 2008
Heater unit doesn't blow any air
If you have no air blowing out it sounds like the blower motor has quit
Dec 28, 2012 | 2005 Jaguar Vanden Plas
Hi there, I just purchased a Jura S9 One Touch. I've used it for a week, maybe making 10 coffees/day. Just yesterday an ERROR 6 message popped up. I don't know what to do, please help?
Hi, Error 6. Haven't come accross that one before. It sounds like brew unit problem.I do know error 7&8 are brew unit problems and 1 to 5 are water flow and heating errors. Try turning off the machine at the main power button and unplug it from the wall for a few minutes. This will reset the machine and right it self. They can do this from time to time. Dazza
Sep 23, 2011 | Jura Capresso Impressa S9 Coffee...
Model WFW9600TA01 - error messages SUD, F21 and F22 keep coming up. machine has not been used for 2 weeks.
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it.
F22 error is a door lock error, if you have already replaced the complete door lock assembly and the issues is still there then check the wire harness connections to the door switch/lock Unit and Central Control Unit (CCU). If the wire harness is fine then the issue is with CCU that should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 15, 2011 | Whirlpool Washing Machines
I need the phone number for the Larry Myers dealer in Bridgeport, WV. I have tried the number given online (304-366-3311), and it doesn't work. Is there another number to call for service?
HI, Google search yeilded this address and phone number:
Larry Myers Subaru
750 Lodgeville Road
Bridgeport, WV 26330
(304) 848-6000
Hope that helps, Mike
Jun 21, 2011 | Hyundai Elantra Touring Cars & Trucks
A 05 304 error code diff sound comes from the
That is a master disposal jam. Check to see if a belt is off in the disposal area.pull out the drum and disposal box to see the belts check you may need a flashlight.
Jun 13, 2010 | Riso RZ220 Duplicator
System unit error in pentium 3 compaq presario
304 error reffers to keyboard error. Verify if your keyborad is properly plugged in, also verify if it's working (pressing Num Lock will turn on the led, pressing again will turn off).
If you plugged in an USB keyboard it won't work, it is necessary to be present an PS/2 keyboard.
Sep 02, 2009 | R.A.M. Computers Compaq Presario 1075,...
Xd card error in Olympus u850sw
HI there,
First thing to do is format the memory card using your camera before using it.
The card need to be formatted on the unit, in able the camera have to recognized the file format of the card inserted to the it.
Hope this initial helps.
Let me know for further confirmation of your problem.
Regards,
micro
Jul 19, 2009 | Olympus Stylus 850SW Digital Camera
Wireless don't work,I can only use internet explorer when ethernet is plugged in.I have good signal from my server box in either way. [ airmax 101
first of all change your wireless settings again.if it`s vista choose WPA,if it`s xp choose WEP.Try the channels from 3,6,9,11(and 13 if it`s available depends on your country).disable MAC security if it`s on. try connecting now.try to use internet.if not then goto start - run - .cmd - enter..type ipconfig.ping the default gateway,if successful then ping 4.2.2.2 ,if successful then ping www.yahoo.com.all ping statistics should say sent = 4,received = 4,lost = 0.if not u need to disable all securities like firewall and antivirus.update adapter`s driver & router`s firmware.provide fixed IP under wireless network connection and DNS server address should be 4.2.2.2 & 4.2.2.3. restart your computer it should work.if it doesn`t then change ur wireless settings again and connect without security.
come back for more advance steps if it doesn`t work.also provide model of router. Thanks..
May 27, 2009 | Acer Computers & Internet
Dishwashers Logo
224 people viewed this question
Top Dishwashers Experts
