Advent 7013 Black Screen
Having a problem with my Advent 7013 Laptop. The screen will some times go dark. The image is still there only the backlight is not on. This is fairly random and pressing the Hibernate button switches the backlight on again as it shuts down, very annoying. Next time it starts up it is fine and will continue to work for the rest of the day, often the new few then it does it again. I have formatted the hard drive and re-installed windows XP but this has not helped.
Any ideas?
    Novelist:
    Scholar:
  • 114 Answers
This is a physical problem with either the backlight itself, the PMU or the inverter cable.
If you have Coverplan extended warranty on your laptop call The TechGuys on 0844 800 60 20 and arrange for the laptop to be collected, yes I know The TechGuys ****, that's because when the call-centre was handed over to Capita call-centre management they constructively dismissed all the technical staff and replaced them with minimum-wage script monkeys, but this laptop is a DSGi product so it's up to them to arrange repair.
If you no longer have a warranty you should shop around for a quote.
Posted on Mar 13, 2008
Is on but black screen
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
IBM R50
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 22, 2009 | IBM ThinkPad T23 Notebook
My screen is dark
Check out
www.lcdparts.net
Jun 21, 2009 | MSI M670 Notebook
Advent 7098 faulty screen?
Angle the screen to the light. If you can see a faint screen image then it's probable that the backlight's inverter has either failed, it's cable has become damaged or the backlight has failed. Both of these can be tricky to replace unless you have the right tools, but can be done provided you can get a spare. Usually it's a tech job.
If the image is not there then it's either the screen itself, the graphics chip or, more likely, the ribbon cable that connects the screen to the motherboard.
You can rule out the graphics chip by plugging the laptop into a monitor.
Of course, the ultimate problem is that you've bought an Advent laptop! And most techs agree that Advent produce the worst laptops in the world. :(
Jun 07, 2009 | Computers & Internet
IBM ThinkPad X31
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 30, 2009 | IBM ThinkPad X31 Notebook
Back light or inverter. my screen is black.
Mar 28, 2009 | Dell Inspiron 8600 Notebook
Can not see anything on the screen
Mar 28, 2009 | HP Pavilion dv9700t Notebook PC
Computer comes on but not the screen.
Mar 25, 2009 | Gateway MX6453 Notebook
M/c is on black screen
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Computers & Internet Logo
416 people viewed this question
Alun Cox
David Payne
David Payne
