Question about Ovens
Oven slow to heat and top burners weak flame
Lately I have noticed that it takes my Gas Oven much longer than normal to preheat. Also, You can only keep 1 burner going at a time or the flames on each of the burners are almost nothing. This is a fairley new stove and am at a loss on what to do to fix. Any suggestions
    President:
  • 2,651 Answers
Sounds like you have a gas pressure /flow problem. id start with hte gas company have them come out and check you tank pressure(if using LP), or the pressure from reguator leading to home
Posted on Mar 14, 2008
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Oven not heating properly
    I think the burner coil is damaged or needs to be replaced. Check it if its damaged then you should replace it then it will work surely at definite time.
    Dec 08, 2007 | Ovens
    Gas oven takes 30 mins or more to to preheat
    Open the bottom and have a look at the burner while its heating. The flame should be strong blue/white and both sides the same, if they are not you have some blocked holes in the burner. Remove the burner and clean out the holes (carefully, don\'t ream them out, use a small paperclip to clean them, be gentle.). Above all do NOT use any kind of oven cleaner on them, if they are aluminum, and most are the oven cleaner will destry it.
    Jul 29, 2014 | Kenmore Ovens
    Kenmore Gas Range. Top burners work fine. Oven is slow to preheat. Igniter has a yellow glow and the burner lights within about 20-30 seconds later. However, the burner has a very small flame and it takes...
    the ignitor should glow bright orange.it sounds like you have a weak ignitor but if the flame lites within 20 to 30 seconds it sounds like it's ok,it could be braking down though when it gets hot,it doesn't matter if it glows,it has to be putting out 3.2 amps,if you have an amp meter with a clamp on it you can read out the amps,if the broiler works ok i would change out the ignitor,then follow the tube down to the bottom and stick a paper clip in the orifice hole where the gas comes out and make sure that's clear,also there's a shutter on the tube to adjust the air flow,see if it's closed,it's usually almost wide open,check the tube to make sure the ignitor didn't burn a hole through it.i've found tubes with holes in them from a lazy ignitor,most of the time if there's a problem it will be the ignitor
    Jan 23, 2011 | Ovens
    Oven appears to start, takes forever to preheat,
    This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
    Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    I have a RCA gas self cleaning oven,It heats on broil but not on bake.we have noticed over the weeks the oven was getting as hot as the thermostat was set at.Now it won't heat at all
    Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Feb 13, 2010 | GE Ovens
    Slow and uneven ignition on the oven burners that causes the oven to take hours to preheat
    MOST OF THE TIME THIS IS CAUSED BY A WEAK IGNITOR.WHEN THE IGNITOR IS WEAK IT WONT PULL ENOUGH CURRENT THROUGH THE GAS VALVE TO OPEN IT UP.SOMETIMES IT WILL OPEN ONLY PARTWAY .GOOD LUCK!
    ERIC
    Jan 23, 2010 | Viking Ovens
    Oven is slow ot light and has a gas smell when
    Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Jan 21, 2010 | Kenmore Ovens
    Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
    This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
    Jan 14, 2010 | Amana Ovens
    Oven takes 5 minutes to come on (ignite).
    Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
    Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
    Ovens Logo
    175 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
