Question about Symbol Spark LS 1004
LS 1004 Symbol Barcode Scanner
I am hoping someone can help me figure out how to use my LS 1004 Symbol Scanner. The scanner is quite old and probably hasn’t been used for a while. From what I know it was supposed to be used with an old IBM ThinkPad. I did not purchase the scanner and just found it recently. I would like to be able to use it to enter samples into an excel spreadsheet on a Dell computer. Is that possible? I read through the entire manual and am quite confused with what are the Host Type and the Synapse. The scanner I have is attached to an adapter, which can hook it up to the mouse/keyboard plug of the computer. I would greatly appreciate your help!
    Scholar:
  • 117 Answers
The host type are the Interafces which are supported by the scanner directly (no adapter needed). And the Synapse adapter can even an old scanner connect to new interfaces like USB.
As you state you have the adapter for keyboard wedge. You would just need to download the Reference Guide for the "Synapse Smart Cable" at support.symbol.com a configure it acccording to your connection parameters.
Posted on Dec 05, 2010
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
When I scan a barcode with the Symbol LS 4278 scanner it duplicates the barcode. How can I fix this?
There was probably some kind of ADF Rule applyed, please scan the barcode Set All Defaults and Erase All Rules from ADF Chapter in the manual for LS4278 aailable here http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6983404apdf&sliceId=&dialogID=190394003&stateId=1%200%20190388491
May 03, 2010 | Symbol LS 4278 Barcode Scanner
Symbol LS 4000-I100 to a PC Help connecting
That depends on your exact model, it could be USB, Keyboard Wedge, or RS-232. In any case, you just plug it in and turn it on.
Oct 15, 2009 | Symbol PN: LS4000-I100 Laser Scanner...
Scan a barcode and the help menu of the program. LS4000i
Disconnect the scanner from the mouse port or disconnect the mouse from the scanner. The scanner must be connected to the keyboard port and have a keyboard attached to the scanner.
Aug 05, 2009 | Symbol LS 4000i Handheld
Set up for Symbol LS5000
Hello Fenandez,
there is no driver needed. Just select the programming barcode for the interface (RS232, Synapse,Wand) you want to use on your host device. You would need just the Reference Guide with the barcodes.
Aug 19, 2008 | Symbol LS 5000 Barcode Scanner
LS 1004 Barcode Scanner
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Mar 14, 2008 | Symbol Spark LS 1004
Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Jan 22, 2008 | Symbol LS 4278 Barcode Scanner
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
What do you mean? you can only scan not more than 3 times? If that so,you need to change the setting of your scanner there was a limit numbers to scan. You can check by using the manual of that scanner.
Hope you like my solution please rate me SOLVE.
Best regards,
Philip
Oct 18, 2007 | Symbol Spark LS 1004
Symbol LS-9100-4008A
Hi I'm trying to find keyboard wedge Configuration to re-program my scanner
It's a symbol LS-9100-400BA and connections if you can fax to 1-956-546-8752
Aug 28, 2007 | Symbol LS9100 Hands Free
Symbol Spark LS 1004 Logo
369 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
