Question about Canon imageRUNNER 5000 Copier
System problem machine going to load its system but it remain in wait mode without giving ready
  • 62 Answers
Sounds like the HARD DRIVE is unserviceable, especially if it never gets past its logo and WAIT screen. Gonna need a replacement and system software installed on it. Definitely requires an engineer.
Posted on Mar 16, 2008
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Feb 01, 2012 | HP DESIGNJET T770 Printer
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
C8180 oxc 18a0306
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
Dec 23, 2011 | HP Photosmart C8180 InkJet Printer
Error 0xc18a0106
Step 1.
Step 2:
......END....
Dec 12, 2011 | HP PhotoSmart Office Equipment & Supplies
Error code 0xc19a0035
Step 1.
Step 2:
......END....
Dec 09, 2011 | HP PhotoSmart Office Equipment & Supplies
When i turn my computer on my momitor wont come on without my help i have to push the button on side of monitor6 time then it comes on
Are you giving the computer time to begin sending a signal to the monitor. Some computers send a brief low resolution signal during BIOS load, then put the video back into sleep mode while loading the operating system. The video drivers are usually loaded fairly late in the boot/OS load cycle. You may just not be waiting long enough.
Jul 04, 2011 | Gateway (G-MAX2000) Computer Speakers
My computer will turn on go thru all the motions like it is working it says windowsxp then goes to welcome screen then goes to my screen it wont show any programs or the start
It seems the Explorer.exe is not running properly or isn't loading. Press Ctrl+Alt+Delete (when it shows nothing on the screen) on the keyboard, the Task Manger will pop up, click "File" and select "New Task (Run)" and type in "explorer.exe" (without quotes), wait for few seconds, it should open up all the features properly, if this fails, go into Safe Mode and try again. To go into Safe Mode, restart the computer and keep tapping the F8 button on the keyboard until you see the Advanced Boot Options with Safe Mode as one of the options. Select Safe Mode using the arrow keys on the keyboard and press enter, you will see white texts in the black screen, wait until you see a warning to confirm whether you want to boot into Safe Mode or not, give a positive input and proceed forward, once windows is loaded, you better run a full system virus scan or I would also recommend System Restore.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 02, 2010 | Compaq Computers & Internet
How to take ups in manual bypass mode.
You definitely want to follow the manual procedure to avoid a possible load loss:
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9390.aspx?cx=3
9.1.4 Transfer from Normal to Bypass Mode
To transfer the critical load to Bypass mode:
C A U T I O N
In Bypass mode, the critical load is not protected from commercial power interruptions and abnormalities.
1. Press the CONTROLS pushbutton on the main menu bar. The System Controls
screen appears.
2. Press the BYPASS pushbutton on the System Controls menu bar.
The UPS transfers to Bypass mode and the critical load is immediately supplied
by the bypass source. If the bypass source is not available, the power processor
remains on and an alarm sounds.
3. The UPS is now operating in Bypass mode and the BYPASS status indicator is
illuminated.
The power module (PM) status indicates READY. The system is now on bypass
and the UPS power processor remains on.
At this point, you can operate an external bypass switch to get to maintenance bypass if needed.
Oct 14, 2009 | Eaton PW9390 UPS System
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
Printer canon
there is the heater bord problem in your printer
Sep 15, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 5000 Copier Logo
49 people viewed this question
old marine
old marine
