Question about Toshiba Satellite M35X-S109 Notebook
Laptop Power I have a Toshiba M35X S109 who's power jack popped off of which I was able to solder back on. However, I can charge the battery and I can power the laptop but not at the same time. When I'm on AC power, the battery is still being discharged. The batter will supply power for ~2hrs.when on its own so I didn't think the battery was in terrible shape. Is it that the AC adapter can't handle the load and is going bad or something else? Thank you!
  • carlcat Mar 13, 2008
    It is the jack in the back but I ohmed it out and all seems well. Might there be a automaticpower selection switch(between AC and Battery) in this model that might be severely confused?
Everything works fine without the battery and the setting I've seen in either the cotrol panel or the bios son't seem to address my crazy problem. I was wondering, I don't have all the screws installed to hold the backshell and front cover in place. There seems to be some conductive pads around the screw holes on the motherboard. Could this be a factor?
Posted on Mar 14, 2008
    Genius:
  • 3,587 Answers
Was the power jack that 'popped off' the one in back of laptop? sounds like perhaps part of that shorted out, and only one side of that connection is running
Posted on Mar 13, 2008
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    try it without the battery at all, and see how that goes..also, check the battery settings in the control panel
SOURCE:
Processor upgrade in a toshiba satellite m35x-s109
A Pentium M 1.7 (SL7EP) works great and runs cooler.
May 01, 2010 | Toshiba Satellite M35X-S109 Notebook
I have a Toshiba M35X-S109 and it won't boot. The power light will come one, I can hear something (like a fan) for 1-2 sec and then nothing. Any ideas?
do a hard reset, it might work.
take out the charger and the battery, press and hold the power button for about 20-30 secs. put back everything inside. and now see if it works.
Apr 29, 2010 | Toshiba Satellite M35X-S109 Notebook
Is good to buy a refurbesh Toshiba Satellite M35X-S109Pc
That depends.
If the battery holds a good charge and it comes with documentation and more importantly at least 90 days warranty then yes it probable is worth buying a refurb. Mose so if the refurb was don't by Toshiba or an AUTHORISED Toshiba agent.
Aug 17, 2009 | Toshiba Satellite M35X-S109 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Toshiba M35X
Just plug the correct ac adaptor into an electrical outlet.  This will recharge your battery as well.
Oct 21, 2008 | Toshiba Satellite M35X-S109 Notebook
M35X-S109 NO Power
Maybe the power led has the problem. Try to check it. ^_^
Feb 08, 2008 | Toshiba Satellite M35X-S109 Notebook
Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Problems sounds like a damaged power pin from pulling or jerking on the AC cable. I use a Cable Retention Device like the one in this video to keep from hurting the pin.
Dec 29, 2007 | Toshiba Satellite M35X-S149 Notebook
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Oct 15, 2007 | Toshiba Satellite M35X-S109 Notebook
Toshiba Satellite M35X-S109 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
