Question about ASUS A8N-SLI Motherboard
Help with motherboard fan making noise
Hi:
As of late, a small fan on my motherboard, covering the nforce4 SLI chip I think, is making a ton of noise. Is there a way to remove it to clean and perhaps lubricate it?
Any ideas?
  • junkman12 Mar 13, 2008
    How do I get the fan opened? It has a cover on it of sorts?
This board is known for doing exactly what your describing. what i did was removed the cover and fan itself and replaced it with a small fan from radio shack. when you go there look for a fan that is the size of the heat sink. Also you may need to find yourself some screws to place it on the heatsink. Try going to any computer shop as well they should also be able to help ya out.
hope this works.
Posted on May 04, 2008
The lubrication is a good ide,but put very minimal oil,and very clean oil.
Posted on Mar 13, 2008
  • 796 Answers
The cpu fans are available in market for pretty cheap rates...
better you can replace it....
thankyou...
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
Plastic fan housing over processor retaining pins snapped meaning fan fell off can i get a replacement and where
this problem happened me too. but unfortunately there is no replacement or spare part for this.
but instead of wasting time by looking for a spare part buy a new fan.
it is not too expensive.
for example i bought a "Cooler master Xtream" fan about 10 USD.
Jan 09, 2011 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Motherboard specs JM679 m6300
According to DELL, the compatible processors with this unit are the Intel T7700, T7500 & T2750, also model T1300
Sep 18, 2009 | Dell Precision M6300 Mobile Notebook
Got a msi k8n neo4 motherboard. can't find a replacement fan for the nforce4 ultra chipset. thanks
Hello there:
you can normally get the replacement parts at a reputable computer repair store or contact the manufacture of the board and they can also help you get the fan that you need ok.?
best regards michael
Aug 27, 2009 | MSI K8N Neo4 Platinum/SLI Motherboard
Computer shuttoff right after I TURN IT ON. I CHECKED IN THE CASE a GREEN LIGHTzaidhorse@ on board STAY ON PCU FAN START AND SHUT OFF CHASIES FAN TURN ON AND OFF WHAT IS THE PROBLUM AND HOW IT CAN BE SOLVE...
Try replacing ram on another slot (common solution for most of the problems like this) , remove the cmos battery and place it back after few moments. Try remove and place Graphics card again.
It should solve your problem.
Apr 03, 2009 | Intel Asus P5ND2-SLI Deluxe...
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
SLI NOT WORKING
well do u know what sli means? actually this is sumthing that u interconnect to video cards n its requirment is dat u'ave to download the latest nvidia drivers for it, if still da prblems not solved contact me!
Nov 18, 2007 | AMD Motherboard, nForce4 SLI, S939, Athlon...
ASUS A8N-SLI Motherboard Logo
78 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
