Question about Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television
Thin red horizontal lines across screen
Your answer to grghson was truncated for some reason....
Don't know if this is the same problem but I get slightly curved thin red horizontal lines across the screen. They are stationary.
The TV is new it me (its 5 years old) and I have it hooked to a Tivo with standard red/wht/yellow cable. The Tivo is on rabbit ears.
Can you help
mystic 100
  • mystic100 Jun 06, 2008
    Very helpful. thanks.
    soon after I posted one of the genius' at Fix ya responded with the same fix.
    It worked.
    We've been happy campers ever since!
    mystic 100
    Habit-Forming:
  • 15 Answers
While looking at your TV, remove the bottom right speaker grill. There you will find a cover held by a couple of screws. Remove the screws and behind the cover you will find the "focus pack" which is a group of 6 adjustment screws. The top screws adjust (in order from left to right) the brightness of Red, Green and Blue.
What you will do preferably at night (or with the room dark) turn the top left adjustment screw (Red) all the way to the left and then gradually turn it to the right until the point you can see the retrace line and then turn it slightly to the left until the retrace line disappears. That's it! You can do this for all three colors - if need be. These do go out of adjustment every now and then. The 3 screws on the bottom are to focus the colors individually to minimize "bloom" on the screen. It's best to be in service mode on your TV when doing this OR open up the cabinet and cover (with something) the other 2 colors while you adjust the focus of the color you're adjusting.
Good Luck!
S
Posted on May 21, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Sep 03, 2009 | Philips 42HF7444T 42 in. Plasma TV
Red lines across bottom portion of screen
usually strong magnets like those in speakers cause lines on tvs if placed to close to the tv.
so demagnitizing the screen should work .
you may have to take it into a pepair shop to do this.
but if thats not the problem. you moe than likely are seeing a common problem of tv screen burn out. and these new tvs tend to burn out faster than the old ones did.
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Jul 26, 2008 | Sony KP-51WS510 51" Rear Projection...
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television Logo
283 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
