Question about Frigidaire GLWS1233A Top Load Washer
In the rinse cycle the washer is making a squeeking noise
I have a top loading washer and in the rinse cyle it was making a squeeking noise so I took the clothes out and turned off the machine
Larry
  • 796 Answers
Check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Posted on Mar 13, 2008
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Kenmore High Efficiency top load washer hung in rinse cycle
What is the complete model number of your unit?
Dec 09, 2012 | Washing Machines
My GWL11 has been making a loud noise for a few weeks and I just tried to wash a load of clothes and it stopped on the rinse cycle and wont continue. I have tried to turn it off and back on to the rinse...
sSorry to read about your problem, I hope this helps you out.
You must have lost you water pump, that was the noise you where hearing
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
My kenmore washer model 110.27802690 will not spin and will not drain the water. the motor will make a humming noise but won't come on. we took all the clothes out and it will now fill up the washer, wash...
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Mar 02, 2018 | Kenmore 24032\24036 Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
The washer is no longer going through the rinse cyle
Check the timer, which is behind the knobs, and check also the power supply. If both work, then move ontothe relay, if still no avail go to the computer board
Feb 09, 2009 | Amana ALW880WH Top Load Washer
Washer stopped running
check the pump on the machine if its clogged it wont let the washer drain
Dec 31, 2008 | Maytag Washing Machines
Clothes washer just makes a noise like a gear spinning ?
I was having the same problem with mine so I took it apart. There is a plastic coupler-like device that connects the drive motor to shaft which allows your "spin" cycle to commence. This coupler has posts in side it but they are under the little belt. My posts were all broken so the bottom piece of the coupler was spinning but the top was not, so it just made a humming noise. This part is available at
http://www.searspartsdirect.com
partNumber=3363664
Nov 24, 2008 | KitchenAid KAWS850L Top Load Washer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
97 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
