I thought it was the battery, but even after installing a new battery the LED indicator (sort of a broken circle with a line at 12:00) flashes and it won't power up? Any help greatly appreciated
Comments:
Mar 13, 2008
- Yes I let it charge overnight through the power lead from about 9 pm to 5 am and it didn't work....
-   I replaced the 6 cell with a 12 but now it will only power up when plugged in. Then I can disconnect for hours. -   ottocf
Apr 24, 2009
-   I put in a 12cell because the old wouldn't hold a charge, now it won't power up unless plugged in but after starting then I can disconnect the power cord for hours. -   Guest
Dec 02, 2008
-   DITTO, my pc wont start up. swapped out power cords? what next? Will it boot w/ out the battery installed? READY TO REBUIL?-   Guest
Nov 19, 2008
-   HP Pavillion dv6000 won't turn on. I press the power button, the lights come on for 2 seconds, and they they're back off again. I've tried taking out the Memory Module and then replacing it and that didn't work. I also tried taking out the battery for 5 minutes then trying to turn it back on but it still won't work. Please help!-   oobuckeyesoo
Sep 05, 2008
-   Laptop will not power up. Black screen. Will not turn on at all.-   Guest
Dear Russ,
let me know ,did you charge the battery through input your power lead in your laptop, because some batteries need to 8-9 hous to charge. try this solution,i hope it will work.
cheerup
Comments:
Mar 14, 2008
- Dear russ, Then you have to contanct ,with the dealer ,who supplied you this battery .you have to replace this battery.
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area...
(More)
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area but
Acer 5735. There is no help section file on the recovery discs and they do not run automatically How...
(More)
Acer 5735. There is no help section file on the recovery discs and they do not run automatically How is the recovery carried out?
have a toshiba satellite pro 6000 which when turned on flashs 3 lights which are the hdd sd and...
(More)
have a toshiba satellite pro 6000 which when turned on flashs 3 lights which are the hdd sd and power lights then turns back off and shows a orange on the dc in light. and will no do any thing else. please help.
Hello... I am facing the problem with the NOVO key too and the solution given here...
(More)
Hello... I am facing the problem with the NOVO key too and the solution given here http://www.fixya.com/support/t1919382-problem_novo_key didn't seem to work for me.... I also got information over the net, that if partitions are altered, then NOVO key wouldn't work.... and FYI I have not touched the partitions at all. The "vista" on my "Lenovo Y500" crashed all of a sudden and since then I am unable to restore it to the "Factory settings". Also I am unable to recover the Factory settings with recover CD. Am I missing something here??? Can anyone please help me with this issue ? This Y500 model seems to be a **** for me.... the Laptop works a little wierd especially the DVD drive.... anyone else facing the same problem???
the ZV 6000 would not power up at all, so I bought a new battery, and followed instructions to allow it to discharge and recharge. The discharge worked, but nothing since, and yes, the adapter/charger is plugged in. The blue flash sign will flash once, sometimes twice, when I press the power on key.
Comment by Guest, posted on May 18, 2008
My battery indicator says full, the battery is in and the light goes from amber to green but when I unplug the AC power the laptop turns off.
I had the keyboard replaced because of sticky keys, and sine then it does not work on battery, is there a setting to turn the battery on?
I have a zv6ooo HP laptop. It runs beautifully. However, I am about to go on a road trip and want to continue doing some offline work. I have never had the battery in the computer. To charge it, do I simply put the battery in and plug it into the AC outlet. Dumb, I know! I've never been where I needed to use the battery.
