Question about Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System
Fuel pump relay switch
I know that it is under the glove box , but wich one is it?
  • steel wool Mar 13, 2008
    please the sooner the better
Look for the ECU fuse.
Posted on Apr 05, 2008
04 Lincoln Navigator fuel pump relay
look behind the passenger frt. kick panel under glove box
If you need further help, I’m available over the phone at https://www.6ya.com/expert/lee_9bf2e1a3cef596dc
Oct 02, 2017 | 2004 Lincoln Navigator
Where is the fuel cutoff switch located on a 2004 Chevy Trailblazer.
There is not a fuel cut off switch for a 2004 Trailblazer. Have your fuel pump relay checked, if it is good I would look at having your pump tested.
Feb 01, 2017 | 2004 Chevrolet TrailBlazer
My 94 Chevy s10 truck 2.2 liter 4 cylinder manual motor has a fuel problem no gas is getting to motor and I replaced fuel pump! Where is FP relay switch located?
You might have a distributor pick-up problem. This is what fires the distributor. When it registers the engine is turning it turns on the fuel pump. And the relay should be on the firewall above the heater box.
Jun 06, 2015 | 1994 Chevrolet S-10
Where is the relay switch for fuel pump for 1995 oldscutlas ciera??
Are you talking about the relay that switches on the pump upon start up? Some are located in the fuse box under the hood. Others may be located behind the glove box. You can usually hear it click or engage when you turn the key to on as the pump pressurizes the system.
Aug 24, 2014 | 1995 Oldsmobile Cutlass Ciera
How can you get juice to go thru to the wires to the fuel pump shut off switch to the fuel pump in a 96 ford thunderbird
check fuel relay and should be a reset switch under glove box at top of floorboard
Mar 19, 2014 | Cars & Trucks
I can't find the fuel pump relay on a 95 camry. I looked in the fuse boxes by the battery,and under the glove box and behind the kick panels. I even looked in the glove box.
What engine? Only the 1MZ V6 has this relay. On the 4-cyl, the fuel pump runs off the circuit opening relay, which is in relay block 6, behind the instrument cluster.
Aug 07, 2013 | 1995 Toyota Camry
Cant locate the fuel pump relay
Hi there:
The fuel pump relay is located to the right of the glove box.
After the insulation panel is removed, the fuse/relay panel will be to the right of the glove box. The insulation panel should have a diagram of the fuse/relay panel layout.
Hope this helps.
Mar 15, 2012 | Cars & Trucks
1999 Cougar: where is the fuel pump relay located on a 99 mercu...
ok your cut off switch is under the glove box in the passenger footwell in the UK version, and mine did not have any further relay until the wiring hit the fuel pump itself, i had been told it was behind a panel in the back under the rear passenger windows, but having removed the entire inner trim of the rear of the car could find no relay at all. my problem was not relay in the end but a dead fuel pumpconfirmed by checking that i9 was getting voltage delivered to the pins of the pump plug when ket switch in position 2 as that is when the pump primes the engine
May 18, 2010 | 1999 Mercury Cougar
Where's the switch?
To my knowledge, there is no separate switch to activate the fuel pump. The fuel pump is one of the many electrical devices powered by the ignition switch when turned on. This is necessary since the fuel pump must be active if and when the engine is running. Due to electrical design, that is to reduce current passing through the ignition switch, a relay is used to along with the ignition switch.
Often, this relay would be among the many relays in the fuse/relay box in the engine compartment pretty close to the battery. However, in your particular model and to my knowledge, it is under the dashboard. More particularly, the fuel pump relay is under and to the right of the glove box above the ECU. There would be two (2) other relays in that area and the fuel pump relay is the last almost hidden.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 24, 2008 | 1993 Toyota 4Runner
Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System Logo
142 people viewed this question
Top Minuteman Computers & Internet Experts
Larry Chandler
Marvin
Marvin
Joseph Hoffmann
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
