Question about Maytag PYG4500A Gas Dryer
Maytag dryer PYG4557AWW
Dryer turns my clothes black. It is like a black soot on the inside of the door. What is causing this?
  • fscraig Sep 07, 2008
    We have the same black soot problem. We have had our dryer for quite a long time and never had the problem before. We have propane gas and it has always been hooked up to the propane line. We had a lot of black soot inside the dryer around and in the burner area which we cleaned out. The problem still occurs.
  • Anonymous Mar 08, 2009
    Black soot on inside of Maytag Performa. Always burned natural gas from new. Is this a bearing or roller wheel issue? About 5 years old and has happened within the last year. Trash it and buy new?
    President:
  • Maytag Master
  • 2,651 Answers
Sounds you have a gas issue for sure, did you recently change from nat gas to bottle gas??? is this a new purchase??? sounds as if your burning a natural gas setup on lp gas call back the installer if thats the case
Posted on Mar 14, 2008
Black soot causing whites to be gray
I too have the same problem with my Admiral dryer. Have come to the conclusion that the soot is making all my clothes greyer, but just noticed it with my whites. Took apart my dryer today and first of all found that the outlet below the lint vent was plugged. There is no soot on the outside of the drum or the dryer housing...however there is soot within the metal tube that surrounds the gas burner. Seems the gas is not being burned properly or the plugged lint trap was not letting the burned gases escape??? Laura
Jul 17, 2010 | Maytag PYG2300A Gas Dryer
I have a Maytag Neptune gas dryer and recently light colored clothes are coming out with small black marks on them; it looks like grease/oil stains. Where could this be coming from?
my first guess would be something ,someone placed in dryer perhaps coveralls or oily clothing.There is no place that I am aware of on a dryer where you could pick up oil leaks from ..are you sure you did not have a lint fire,the oil stains may be soot
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
Black carbon/soot on the door and lint filter of my dryer
Soot would mean lint is circulating around in your machine, and getting to the combustion area. Take the machine all apart and clean it thoroughly, including taking the cover off the fan and cleaning it too. A dirty fan will slow down the whole works. Check with your hardware store for a chimney-sweep's brush. I once bought one that could be tied to ropes and pulled up and down a flue. If they have a brush the right size, you could do that and really clean your dryer vent.
May 12, 2009 | Crosley CDG6000 Gas Dryer
I have Maytag PYG4557AWW dryer. My clothes won't dry very easily. In fact it took more than 3 hours to dray a load. The inside bin does turn and there is heat. Since I don't see warm air coming out of the...
Your close. It's more than likely your house vent (flue) is clogged. Disconnect the hose at the back of your dryer and run it for about fifteen minute, if you see an improvement, then clean the house vent. If no improvement. Then your valve coils need to be reoplaced
May 05, 2009 | Maytag Dryers
Black Film on the inside of the dryer drum. Transfers to clothes.
The gas is not mixing properly with the air. You could have a blocked or restricted vent which has caused lint to back up in the machine thus giving you a poor burn. Check your venting and if it is clogged you may need to dismantle the dryer to clean it out inside. :)
Apr 09, 2009 | Dryers
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
A dark residue inside of dryer
Sounds like an ink pen was left in the clothing during wash and leaked out when put in the dryer
Oct 21, 2007 | Maytag HYE3658AY Electric Dryer
Black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Jun 28, 2007 | Whirlpool GGW9200L Gas Dryer
Soot in dryer
sounds like you migt have had a flash fire in the vent line. you need to open the dryer and clean out the vent line
Dec 13, 2006 | Crosley CDG6000 Gas Dryer
Maytag PYG4500A Gas Dryer Logo
314 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
