Question about RCA H100 MP3 Player
Sound from headphones is messed
When the headphones are plugged all the way in to the player, the left ear is really fuzzy. If the volume is low, the left doesn't work at all. If I have the phones plugged in partially, it sounds fine. I tried cleaning it out with rubbing alcohol and q-tips and nothing. Any Ideas?
  • Slayer77 Mar 14, 2008
    I tried that. it even happens when I use it in the car. left speakers are fuzzy.
    Problem Solver:
  • 12 Answers
Get new head phones same thing happened 2 me
Posted on Mar 13, 2008
No sound in ear phones.
Well if you really dont want to buy new head phones , go to best buy. Or look up on google who fixes earphones and where they fix them at. But i highly suggest you to get a new pair of ear phones.
Jan 23, 2013 | Sennheiser RS 110 Consumer Headphones
After soldering, my left ear piece sounds lower than the right piece
More likely the heat from the soldering iron has damaged the earpiece speaker. The cone is plastic film.
Oct 03, 2017 | JVC Air-Cushion Headphones HA-FX66W
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
Distorted sound on blue iPod 8GB nano
make sure heasdphones are plugged in completely
May 22, 2009 | Apple iPod nano
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
May 01, 2009 | IOGear (GBE201W7) Wireless Headset
Left ear going out
Your left ear canal may be plugged. You may have to improvise a way to flush it as you would while taking a shower. Use a cotton swab or equivalent to remove the residue.
As for the earbud, there may be foreign matter lodged inside where it is inaccessible.
If the headphones cannot be repaired, there may be a way to get a replacement expedited to you through one of the support groups.
Jun 20, 2017 | Shure SCL3 Headphones
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Mar 10, 2009 | Bose Around-Ear Headphones - Silver
Problems changing volume & sound horrible
Your player is flipped. It thinks that it's connected to an external device, and acts as if it in line out output. When outputing to line out, you really don't have volume control, and you hear it right with the headphones, you would be missing some amplification. Try to reverse the actions that choose line output: Press and hold BACK. The Home menu appears. Press the arrows to select the settings icon(looks like a suitcase), and then press play/pause. Press the up/down buttons to select Audio Output and press play/pause. Now you should see "line out" selected. move the arrows to another setting - headphones if available, and press play/pause. Now unless something is really wrong with your player it should work. If it doesn't, use your warranty if valid, send for repair. Good luck
Jun 23, 2006 | Sony Network Walkman NW-A3000 MP3 Player
RCA H100 MP3 Player Logo
62 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
