Question about Philips 51PP9200D Television
TV screen problems
I have a Philips Magnavox 51MP392H Rear Projection Television and lately it started turning red and green and leaving tracers around everything any idea of what could be wrong or how to fix it? to much red and green in picture (cross line up) picture has too much red and green and the bottom of the picture looks like someone is trying to turn a page up
  • Philips Master
  • 8,617 Answers
Convergnce IC are bad replace both of them that should straighten out your problem. But also check th resistors right next to th ICs as 1 or 2 of them may be oen as well
Posted on Mar 13, 2008
My magnavox tv has double letters in both red and green images on the bottom 2 inches of the screen
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
When i just the red and green the picture holds when i turn the tv of then back on agian i have to readjust every thing agian
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
The screen is starting to have red and green blurring
sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Green blured color started at bottom left corner and growing
Based off manufactureing timeline it sounds like you have some capicitors going bad you will need to contact a qualified Service agent for a service call to repair the problem.
Jan 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
you will need to replace both STK392-120 Convergence ICs and you will also need four 6.8 ohm 1 watt resistors. You can get the replacement ICs and resistors at the following link with free instructions with pictures,
Sep 26, 2008 | Philips Magnavox 51MP392H Rear Projection...
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
TV screen problems
I had the same problem where all of a sudden it started bowing on top and bottom and the colors were bad. I read on here and other sites about the 2 convergance chips so I figured why not try as the tv was going to get thrown away because I could not find anyone that would touch it. Well I ordered 2 stk392-120's (I know others are saying use the 150's or 180's but I just wanted to put the same ones that were in there) I ordered them from for 9.99 each plus 6.60 for shipping they took 3 days to get here and I installed them tonight and it worked great. The whole thing took only about 2 hours from start to finish. Here's a couple of tips....the chips are on the far left when looking at the tv from the back, make sure you mark with a marker where the wires go that you have to unplug as there are about 10 of them, each chip has 19 pins that you will have to soder make sure you have a soder ****** to get all the old soder up as you are heating them up, after you are done puting it back together leave the back cover off and turn it on, then go into your menu and go to pictureand go to manual converge and go to undo multpoint and restore factory as this will reset it all. Then if your color is still a little off as mine was there are 6 knobs in the back of the tv by the chips you were working on, find a channel with a lot of colors and try adjusting the top 3 a little at a time till you get the right color that you like. This should do it. It took 26 bucks and 2 hours for me to fix a tv I was ready to replace, thank god for the internet to be able to look stuff like this up. Good luck!
Dec 03, 2007 | Philips Magnavox 51MP392H Rear Projection...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
TV screen problems
You will most likely need to have the convergence circuit repaired. Not an uncommon failure with CRT projection televisions. Go into your menus first and check the convergence settings and see what happens.
Mar 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 51PP9200D Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
