Question about Panasonic SC-HT730 System
Possible broken speaker
One of my surround speakers, SB-FS731 isn't putting out any sound. I checked the wires connected to both it and the sub-woofer and they both seem to be fine. I also did a sound test and it still didn't work. What would be my next step?
    Problem Solver:
  • 10 Answers
You must determine if subwoofer amp or speaker are bad.Take the good surround speaker and move it to the bad side.If the good speaker does not produce audio the the amplifer is bad.If you use the good speaker in either surround output and it works then your speaker is bad.If you take the small speaker apart the panasonic part number is stamped on the magnet.Locate a service center that will order it for you.
Posted on Apr 05, 2008
I just got my system today. All the speakers are working, except the sub-woofer. Any ideas what could be wrong (if not DoA)?
Did you connect power to the sub-woofer? Most subs have their own amplifier. Just check if there is also an on / off switch on the sub.
Apr 18, 2015 | Frisby 5.1 Surround Sound Home Theater...
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
Nov 01, 2010 | Audio Players & Recorders
PANASONIC SURROUND SOUND SB-WA3300
May be wrong number. SB-WA330 is name of speakers and search http://safemanuals.com/ to give you the right manual
Samuel
Aug 18, 2008 | Panasonic Home Theater System System
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
Panasonic SC-HT730 System Logo
168 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
