Question about HP iPAQ h6315/h6365 Pocket PC
No signal i am facing the signal problem....in my Hp iPAQ 6365...how to solve this problem
  • HP Master
  • 13,433 Answers
Try reseting the device.
If theres no effect contact your dealer for further assistance. If you need instructions on how to reset your device drop me a line :)
Posted on Mar 17, 2008
I have replace my main battery and it showing 100% charge but I am facing bit trouble.My( PDA HP IPAQ 6365) battery not giving standby. what is backup battery? It is showing 0% charge? please help
The backup battery is not user replaceable. If you have some electronics experience you could open the device and replace it yourself but it involves cutting out the old battery and soldering in a replacement. An easier solution is to take it to a phone repair shop and get a quote to replace the battery, probably around $ 60. They may even give you a 3 month warrantee.
Apr 06, 2011 | HP iPAQ h6315/h6365 Pocket PC
Ipaq 6515 does not locate a gps signal
most probably your Gps module had developed problem.
Jan 03, 2009 | HP iPAQ hw6515 Pocket PC
HP iPAQ Bluetooth GPS, IPAQ has no signal
I noticed now that the 'green lite' on my receiver does not come on at all. I can not find where I can get a replacement receiver
Sep 09, 2008 | HP iPAQ Bluetooth GPS Navigation
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
Battery backup related
Most of your data (phone directory, calendar etc) is stored your pda's ram. If your LiON battery runs flat , the pda wont start up, your backup battery kicks in to preserve the data. If your NiMH battery runs flat, you will loose all data in the phone or the equivalent of a hard reset.
Nov 29, 2007 | HP iPAQ h6315/h6365 Pocket PC
Ipaq 6365
Call the people at this site:http://www.pdabattery.net/
Nov 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
SMS Inbox Disappeared
Hello Brian, The SMS folder dissapears most probably because another program interferes with it. The same happens on some HP's with camera, where this options dissapears from menu because of some user installed programs. In your case, it doesn't have to be a SMS - messaging related program, there are some compatibility issues and programs that apparently doen't have anything to do with messaging are causing this. You should first try a master reset (hard reset) (save your data first). However in some cases this doesn't help, even if the program that's causing the problem is removed, and you will need a firmware rewrite/update. In order to perform this, or if you don't want to risk performing it yourself please contact me on the live assistance for step by step instuctions. Good luck, Bogdan.
May 10, 2007 | HP iPAQ h6315/h6365 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
HP iPAQ 6365
Please perform following steps.
Take the back up of data.
Clean the battery.
Hardware reset.
Perform the Hard reset
1. Press and hold the Answer/Send, Power, and End Call buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
Sep 12, 2006 | HP iPAQ h6315/h6365 Pocket PC
IPaq 6365 WiFi Wont Shut Off
There's a little utility I use (just because it's quicker than the usual iPaq Wireless screen buttons) called WirelessSwitcher. http://www.aspecto-software.com/WiFiFoFum/Utilities.htm Maybe this would do the trick for you.
Sep 11, 2005 | HP iPAQ h6315/h6365 Pocket PC
HP iPAQ h6315/h6365 Pocket PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
