Question about Kenwood KDC-135 CD Player
HIGH PITCH SOUND
I just had this CD receiver installed yesterday and there is a high pitch screeching sound when the stereo is playing. I don't know how to get rid of it.
  • 132 Answers
Sounds like a ground issue, or a problem with the deck, id take it back to where u had it installed
Posted on Jul 25, 2008
SOURCE:
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
Hyundai accent 2005 when starting up the vechile and driving there is a constant ugly sound coming from the front passenger side wheel and when applying the brakes on there is a high pitch squeel
That screeching sound is a warning that your brake pads are worn down to the point where they should be immediately replaced. If you do not replace the pads, you'll score the rotor and incur an additional expense. Remember to replace the brake pads on both sides, i.e., driver and passenger side.
May 01, 2012 | 2005 Hyundai Accent
2002 Montero has high pitch sound from dash and brakes are hard
it sounds like you have a problem with the brake booster it may be a leaking seal that is causing the high pitch sound if you are losing vacuum you don't have any assistance from the brake booster hence the hard brake pedal....cheers
Jul 01, 2011 | Mitsubishi Montero Cars & Trucks
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
Aug 09, 2009 | 2005 Dodge Neon
High pitch sound comming from tv!
The horizontal transistor and the flyback are damaged
Apr 24, 2008 | Samsung TX-P3264 32" TV
Engine noise only when playing ipod through line in adapter
Did it always make noise or did it start recently? You need a ground loop isolator. That usually clears up the engine noise.
Feb 28, 2008 | JVC Sirius KD-LH300 CD Player
Kenwood KDC-135 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
