My Welcome Screen format has changed and not typical to my routine screen. This is random, but frequent
  • Kevin Hirsch May 11, 2010
    Give me a pic of it, and maybe then I can Help...
  • 24 Answers
Or, what you could TRY is hit ctrl-alt-del when it comes up in the logon screen. That might revert it back to the welcome screen.
Posted on Mar 24, 2008
    Scholar:
  • 64 Answers
Hi rjjk45,
I'm guessing that instead of icons you're getting two lines of text for a username and password. Some programs, such as Symantec's pcAnywhere change some security settings and make that change. Try removing any recent programs you've installed and see if it reverts.
You can also try manually changing this. Go to your Control Panel and then to User Accounts. Select the option that says 'Change the way users log on' and you'll get two options. If 'Use the Welcome Screen' is not checked, check that box. If you can't check it or it is grayed out, then some recent software installation made that change.
If this isn't what you're experiencing, please provide the screenshot that smokeymatzo has asked about.
Ben
Posted on Mar 13, 2008
My desktop frequantaly booting what can i do
When you say frequently rebooting; Is it randomly rebooting without warning? Do you get a BSOD (Blue Screen of Death) error message? Or does the PC just reboot without any error's other than windows was not shutdown properly?
MOST random reboot issues are caused by Power issues;
-Failing Power Supply
-Blown Capacitors on the motherboard
-Insufficient power to run the system.
These would be a good place to start to troubleshoot if you do not get a Blue Screen Error Message.
-Failing Hard Drive can cause this issue as well but is usually acompanied by a Blue Screen Error of sorts.
-Failing RAM again usually accompanied by a Blue Screen Error.
You can test for failing hardware, by using Hiren's Boot Disk for diagnostic tests on your Hard Drive or Ram.
Hiren's Boot CD 15.2 - http://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
You will want to run memtest X86 to test the Ram or Hitachi's Drive Fitness Test or SeaTools to test your hard drive.
This BootCD is not for the typical end user whom may not know there way around the features and options this Tech CD provides.
You will want to burn the Hirens Boot.ISO file to a CD (Burn Image Option) using any of your favorite flavors of burn software.
Hope this helps.
You can also download these diagnostic test individually such as memtest x86 and Hitachi's DFT or SeaTools independently from the Boot CD just by doing a google search. This might be the easier way to perform these tests for people who aren't very savvy with boot CD's.
Dec 09, 2013 | Intel D845GVSR Motherboard
Loads up fine but stops on green screen
While computer is starting up, before the welcome screen, push alt and F10, not at the same time, but frequently one after the other till it brings up a screen asking if you if you want to reformat.
Nov 20, 2011 | Acer Aspire 5735 Notebook
Sylvania #7 inch notebook. When i turn in on the screen goes to Welcome to Windows CE and asks for a password. I just bought it new and have no directions that were in the box. Please help !
If it came with a password and no directions were included, you need to take it back to the place of purchase for a proper exchange, and get them to check the new replacement before you except it.
Dec 28, 2010 | Sylvania G-Netbook
My screen goes blank and my computer then
Hi, first of all check your AVI cord by changing it or check your settings if it's set on timing off at certain intervals. then after all said and done format your system.
thanks
Apr 06, 2010 | Computers & Internet
Prior to this, screen size changed at will.....
All you have to do is go in the menu and go to picture...once you are in there turn "Auto format" off.
Jul 01, 2009 | RCA HD52W58 52" TV
Random screen format adjustment!
try blocking the sensor built into the front of the tv. If it cant sence light, it wont change.
May 26, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
MY E815 screen has weird signs
Check this link to see info about your phone.
Apr 25, 2008 | Motorola Mobility E815
Turns on but won't respond
IS IT A LAPTOP OR DESKTOP ?
IS THE WELCOME SCREEN THE WINDOWS WELCOME SCREEN OR THE MACHINES BOOT WELCOME SCREEN ?
IF IT IS THE WINDOWS WELCOME SCREEN then format and reinstall windows followed by your drivers and software
IF IT IS A DESKTOP and its the boot welcome screen (MOTHER BOARD MANUFACTURE) the try flashing the bios, look for jp1 its cloe to the battery it should have 3 pins and a jumper. the jumper should be on 1 and 2 leaving 3 free, put the jumper on 2 and 3 for 5 seconds then putting it back on one and 2.
If that dont work remover the rams and flash again
If that dont work disconnect all hard drives and other drives from the board and see if it boots. IT WOULD SAY INSERT SYSTEM DISK
if that happens it means one of your drive is bad connect it one by one until u find which and replace it..
IF THAT DONT WORK CHANGE YOU MOTHER BOARD
IF ITS A LAPTOP
DISCONNECT THE BATTERY , remove the rams and there is anoter smaller batter on the main board, remove it as well
leave it off for a few minuters reassemble and it should work
IF NOT THE REMOVE THE HARD DRIVE AND OTHER DRIVES and see if it boots
if it does replace the drives one by one to see which is bad
IF THAT DONT HELP take it in to a technician for repairs to the main board
Dec 22, 2007 | Tascam CD-RW2000 Burner
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
