Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Printer won't accept paper
When i go to print the paper starts to feed and then when it comes to the first set of rollers the paper just bunches up those rollers do not move to accept the paper.This happens from the lower tray and also the front feed. The printer says i have a paper jam.there is no paper in those rollers. Also the paper is just normal weight paper
    President:
  • 2,072 Answers
What jam code are you getting. I suspect a registration clutch issue. But there should be a code associated with the jam.
I would like to look that up and narrow it down for you.
Posted on Mar 13, 2008
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 15, 2011 | Office Equipment & Supplies
Have lexmark 1200 series will not feed paper i
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper. although you did this, there might be a small particle hanging you up. I have experienced this before. see if both sides have cogs that catch the roller, one might be offset?
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Office Equipment & Supplies
Paper not feeding correctly
try to clean the carriage and see if a Q-TIP will reach the feed rollers. They probably still have some ink still on them.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP printer will not feed paper through the rollers
Pick up some Print Roller Cleaner spray, and carefully spray your rollers. As time goes on, fibres from the paper embed in the rollers, which reduce their efficiency to pickup and feed paper. Spray all the rollers and set it dry. You should find that your printer feeds paper. If not, you need a new roller set, available from the HP Spares, or a good local HP Dealer.
Mar 14, 2009 | HP DeskJet 5650 InkJet Printer
Paper does not feed all Malfxn lights on
Can you tell if the feed rollers are turning? Depending on what type of printer it is, you feed rollers could be worn and not picking up the paper.
Feb 27, 2009 | HP LaserJet 5p Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Paper jam epson stylus 5400
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 08, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printer won't accept paper to print when starting to go though it just stops..
pls check the ff:
- leading edge of your paper, must be straight
- clean the feed rollers, w moistened cloth, maybe dirty thats why it is slipping
- check paper orientation, must be leveled to the tray
- did you changed any configuration under properties?? check also
we can start from this
pls mark my solutions if it does any help
Jul 30, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Paper Source
ASF
Cassette
Click to return to step 2 above.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
