Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Did not stat printer and scanner - Xerox WorkCentre PE16 All-In-One Laser Printer
    President:
  • 2,072 Answers
Remove the back cover. And looking from the back, remove the right side cover. There is a white ribbon cable and one connector with mostly red wires, remove and reseat those. Return power to the machine and see if it comes on.
If not, then remove the right side cover, the 2 screws that fasten the scanner to the frame, remove the scanner and then the controle consol, ( display.) then unplug all the connectors on the display and reconnect them.
It the display still does not work after reseating all the connectors, the scanner assembly is defective.
Posted on Mar 16, 2008
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
1998 Chevy Camaro - Temp guage reads 50 degrees hotter than what Scanner shows
Check the ground wires at battery to car body, battery to engine and the ground interconnect between the engine and the car body.
Jun 09, 2017 | Chevrolet Camaro Cars & Trucks
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Scanner problem of hp laserjet 3030 all in one
Try unplugging the cord to the printer and wait a few seconds and re-plug the cord again , print what ya have to print again/hope this helps .
Dec 01, 2007 | HP ScanJet 3200C Flatbed Scanner
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
