Question about Lexmark X4270 All-In-One InkJet Printer
Aaahhhhhhh! We haven't used the printer in months because the black in k ran out. (we had another printer) Today, we refilled the black cartridge instead of replacing it with a new one (to save money) and it won't print black-all the other colors work, though.......help!!!  :o)
  • 3 Answers
Try putting the cartridge in hot water , sometimes the ink drys out
Posted on Mar 13, 2008
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
My mp 240 is showing an error P3
P, THEN 0, THEN 3 RIGHT?
Strange thing. I have had this particular printer in question for about a year now. Today I got a similar message, but with an 8.
I ran out of color a while ago and never replaced it, just used the black only feature. That ran dry and I replaced the black and only the black. It has been running just black for many months.
When I researched my problem I found that it may be linked to my color cartridge being out. (but it has been out, for many months).
Nonetheless, I installed a new color cartridge and voila!.. Problem solved.
If you have a cartridge that is low or empty, change it and see if it solves your problem. (Be sure to keep the receipt in case it doesn't work).
Jan 25, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
Trying to reload color cartridge.
Many brand name printer cartridges have a code that tells the printer they are a new cartridge. Once the cartridge is empty it will never again tell the printer that is it new.
You can refill the cartridge but it will continue to tell the printer that it is empty.
You say you "had my ... cartridges refilled today" so I suggest you go back to the folks who refilled them and ask them for suggestions.
Otherwise, purchase off-brand cartridges that won't tell the printer they're empty and keep refilling them as needed.
Another approach: purchase a new printer that won't give you this problem. I refill my Lexmark cartridges without any problems.
Dec 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Aug 10, 2008 | Lexmark X2550 All-In-One Printer
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
Machine does not recognize refilled office max cartridge (black)
sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
Apr 23, 2008 | HP PSC 950 All-In-One InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
