Question about Hotpoint WMA50 Front Load Washer
Hotpoint aquarius wma50
How do i adjust the motor to replace the belt and brushes
  • Anonymous Mar 31, 2014
    i cant get to the motor to change brushes
  • 108 Answers
You should be able to do both without disturbing the motor.
To do the brushes - about half an hour...
1. UNPLUG the washer.
2. check you've unplugged.
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
To do the belt. + as long as your patience lasts...
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
Posted on Mar 13, 2008
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wma50
The motor does not have provision for belt adjostment, it is self tensioning
To gain access to the brushes, you need to remove the motor from the washer.
Remove rear panel, remove belt, unplug motor lead, taking note which way the plug goes,undo screws securing motor, and lever motor back with a screw driver, remove motor and change brushes.
Posted on Feb 12, 2009
Hotpoint aquarius 1000 (wma50p) not taking in water, and i cannot move the drum by hand.
Hello, it sounds like the main motor has blown. This causes the pump to stop as it is connected to the pulleys and gearbox. The only solution is replacing the main motor. Even though it sounds expensive, it should only cost around $100 plus fitting.
Mar 23, 2011 | Hotpoint WMA50 Front Load Washer
Our hotpoint WMA50 is draining but the drum is not turning
Can you hear the motor running if you can all that is needed is a new belt. But if you can not hear the motor running then the motors carbon brushes need replacing. http://www.youtube.com/watch?v=HELgV4KOsT0&feature=channel this shows the carbon brushes on a hotpoint. http://www.youtube.com/watch?v=X1yY_6vKK8g&feature=channel This shows how to change belt. hope this helped.
Dec 28, 2010 | Hotpoint Washing Machines
Motor brushes....how do you change them
Remoe lower rear cover of washer.
Remove earth wire, and unplug motor socket.
Remove belt and remove 2 bolts securing moor. holding moior, lever motor towards rear, and remove motor from washer.
Change the brushes in the motor.
Oct 08, 2010 | Hotpoint WMA50 Front Load Washer
Just replaced jockey wheel on hotpoint aquarius ctd00 but drum still not going round??
Check belt not slipping, Most likly cause is motor brush assembly.About £18.00 to fix yourself
Feb 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Feb 12, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
How do i remove a rear control knob on a hotpoint wma50s machine
to replace your timer dial take the lid of by unscrewing 2 screws at the back of the lid were your dial is look down a small oval shape opening u will see a screw undo it and the dial will come off m8
Feb 18, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
607 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
