Question about Maytag Neptune MAH5500B Front Load Washer
Maytag front end loading washer
I have a Maytag Neptune, still under warranty--it is making a noise upon spinning--I believe a wire from a bra is in between the "basket" and the tank below. Is this easy to repair, or should I call the service?
  • Maytag Master
  • 2,651 Answers
Unless you can physicllly grab the object form inside the tub, perhaprs still hanging through one of the holes, no real easy way to acess between the tubs( the viens inside the tub are secured bya screw never took out but perhaps that will get you a litlle space to grab
Posted on Mar 16, 2008
Why does my washer (maytag mah5500bww front loader) make noise during the wash/rinse cycles but not during the spin.?
The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on the upper hose hitting the top cover ir a plastic injector mold standoff on the outer tub bearing housing, also a flat spot in the belt could cause a tapping noise. Something between the outer tub and wash basket. I have had to remove items lodged in the drain tube between the pump and tub, like bra under wires. Sometimes you can squeeze the tube and feel objects the ate lodged. I always take the tube off the tub side and run my finger all the way down to the pump impeller to make sure. I also check the I can spin the impeller and the nothing is in the pump. Hard to say with out being there. Where do you think the noise is coming from top , bottom , left , or right side?
Apr 30, 2014 | Maytag Neptune MAH5500B Front Load Washer
How to fix the pump in maytag neptune washer
Remove the back panel there are four screws in panel. the pump is acessable on left side facing back. The pump is bad or you have something stuck in the pin, bra support wire, and have found coins in them also. Have towels handy to absorb the water.
Feb 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag Nuptune washer in spin cycle sounds like a plane taking off
Something small, like a paperclip or the wire from an underwire bra can get stuck in the holes in the drum, and rub against the outer drum. You will have to check carefully to find it.
Mar 16, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washer makes alot of noise during the spin cycle almost like the sound of a jet engine.
Check the drum holes carefully, this often happens when something like a bra under wire gets caught in a hole and rubs on the outer drum
Feb 03, 2011 | Maytag MAH8700A Front Load Washer
When my washer is in the wash cycle, it makes a loud clicking noise. It sounds like a maybe a gear is skipping through some teeth. It is loud and at a regular interval, although the rate at which the noise...
its most likely a bra wire caught in there as the bowl spins around it is hitting the plastic tank therefore making the clicking sound. its super hard to get em out and if it has put a hole in the plastic tank its really expensive to fix call your appliance service asap to have one of them take a look. this is a very common problem from a front load washing machine
Jan 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Makes a loud whiring noise only on the spin cycle
take a flashlight and inspect the holes in drum for a screw or bra under wire. check where inner tub meets the outer tub by the door see the little bristles or is it rubbing there maby somthing stuck in there. if it's rubbing there should be 1/4 in gap with bristles if there gone and it's rubbing start looking for a new washer the bearrings are going out and drifting out of there housing
Dec 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune front end washer. model #
First clean out your outlet filter. If this does not work, open up behind and tighten all points where wires are joined; due to vibrations these might have come loose. Plug off the wall first!!..
thank u
May 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
