Question about Coby CTV-555 5 in. Portable Television
Brightness of Ctc
I a have a TV set TCL 29" (74 cm) model EC2988 (flat CRT screen) working since 3 years cm. Since 4 months, i got some red flashes in the screen without any apparent cause for a very short time. But after every thing became normal except that the brightness became bad. I tried to adjust (increase) all the parameters (COLOR, BRIGHTNESS, CONTRAST, SHARPNESS) to obtain a good picture but i couldn't. I also change the input poit (from RGB to RF port)with no result All the colors are presents
Thank you for any advise
Mustapha
3 Suggested Answers
  • 246 Answers
SOURCE: No picture on coby tv
I'm not certain but it sounds like there is a loose video cable in there...if you are able to, take the tv apart, and literally push on all of the connectors and cables to make sure they are not loose. The main video cable may not seem to be loose, but once it is making contact again, it should clear that mess up. Just look for cables running to the main screen and pull them off and put them back. Then put the tv back together again and see if it worked...it usually does. why does this happen? Some blame it on dust, others blame it on quick manufacturing processes...whatever the case, the cables become slightly seperated from the controller board and that happens...it also happens to computer monitors too...Good luck and take your time. If there are a lot of screws and things either take pictures of where they all went or write it down. I like to make a diagram on a piece of paper and tape the screws on the diagram to show where they went.
Posted on Sep 01, 2012
gopakumarg43
  • 75846 Answers
SOURCE: It has a horizontal lines at the bottom of screen,then after a few minutes lines radiated all over the picture and color fades
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the keyword "line fault", in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on May 07, 2016
Testimonial: "thankz again,more power...."
Tcl tv screen
hi go into the menu on your tv scroll to picture setting turn the brightness down also look for bl which means back light set it to about 10 hope it helps
regards
shaun
Jan 25, 2014 | Televison & Video
My TV began with a flash of white light then will turn itself off. It won't turn off every time the screen flashes. It started a month ago then worked trouble free until now and it began again. You can...
I hope you have a service plan for this set. Most likely--the CRT"s are going bad. This was a VERY common problem for Sony sets of this age. the CRT tubes SHOULD last a long time...BUT Sony had a BUNCH of the tubes that had 'contamination" on the cathodes of the guns...and after a few years..this 'flakes off" and shorts out the tubes. There WAS a recall on these a couple of years ago, but I am not sure about it now. You will need ALL 3 tubes to fix this problem. If it was me...I would try and find out if there is any way to get Sony to cover it..., if the set is not more than about 8years old.
Oct 12, 2009 | Sony KP-51HW40 51" Rear Projection...
My CTC TV is locked (remote & screen)
hi! try pressing the display button on your remote for about 5 secs. until the lock disappear then turn it off on the remote. then unplug it.
Aug 20, 2009 | Televison & Video
Samsung HL-R5056
THE MANUFACTURER USUALLY WARRANTS THEM FOR ONE YEAR AND THE STORES FOR 1 TO 3 MONTHS.
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
Daewoo Universal Codes for Comcast Remote
For Daewoo TV Model DTQ-27U4SC, try this for Comcast Universal Remote (one with the red select button):
1. Press TV button
2. Press Setup button until TV button blinks twice
3. Enter 10451
4. Press Power button (TV should turn off and is set)
Mar 01, 2008 | Daewoo DTQ-1440FC 13" TV
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Curtis mathis tv
sadly,,it should be retired...the cm sets were good in their day,,but the money would be beter invested in something that will be ready for the digital airways
Nov 27, 2007 | Televison & Video
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Coby CTV-555 5 in. Portable Television Logo
46 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
