Question about HP Compaq Presario C304NR Notebook
No audio No sound output
  • Jonathan Agawin
    Jonathan Agawin Oct 11, 2008
    I have installed the driver for my laptop presario x1000. after I installed the sound driver- its now working. thanks.
    Genius:
  • 2,785 Answers
Please check if your sound driver is installed correctly
Posted on Apr 02, 2008
Audio output only out of one output
hello sir,
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
good luck
Oct 18, 2015 | Car Audio & Video
Kdl-32v4000 sound
Check the speaker first. Check if there is any sound output comes from the audio out terminals at the back of the TV, by connecting them to any external audio out devices; such as an amplifier or so. If there is audio output comes from the external source such connected, and no audio output from the TV; since the speakers are good, the fault is with the audio output section circuit inside the TV. If there is no audio output from the external sources too, the fault is with the audio processing section circuit at the main board. If this is the case, main board is faulty, and should be replaced.
Aug 07, 2012 | Sony Bravia KDL-32V4000 32 in. LCD TV
Hitachi 32ld8700 ua no sound
Make sure you are not set to SAP mode...use mono or stereo.
Feb 03, 2012 | Hitachi 32LD8700 32 in. LCD Television
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
My iPhone plays videos on the Internet but no sound comes out, why Is that???
If your having problems with no audio from youtube, myspace and flash video. I suggest this
When watching web pages with embedded Flash video or animation such as movie or video clip on YouTube and MySpace using Mac OS X, users may hear no sound. The no sound audio output problem happens despite video playback is fine, and the issue can happen on any web browser, i.e. Safari and Mozilla Firefox. Strange thing is that, when using other applications such as RealPlayer, QuickTime Player and VLC Player, the sound is played properly. And no audio output issue does not affect embedded QuickTime including HD contents on the web.
Apple Mac OS X support site explains that the no audio from certain multimedia content issue is caused by some audio applications that change the computer's audio settings to a sample rate that is too high for other applications to use. The notorious programs include certain versions of Real Player, VLC Player and Audacity.
The solution to solve the Internet movie no sound or audio output is to reset the audio setting in Mac OS X to original configuration:
  1. Open "Audio MIDI Setup" (/Applications/Utilities/), then check the "Audio Output" setting.
  2. Change the "Audio Output" setting to 44100.0 Hz.
  3. Quit Audio MIDI Setup.
If the Audio Output setting is grayed out or disabled, go to "Properties For" tab in Audio MIDI Setup, and select "Built in Output".
I hope this helps
Dec 14, 2010 | Apple iPhone 3G
No audio output installed
Have you installed sound/ audio driver?
Install MSUAA before installing sound/ audio driver, hope sound works well
May 04, 2010 | Dell Latitude D600 Notebook
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I lost Audio output Device No audio output when using turntable. Can hear sound with headphone, can hear sound when hooked directly to speaker. Can not get sound out of audio output. Plugged RCA cables...
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Aug 08, 2008 | Kenwood KR-V7080 Receiver
No sound from output 3/4
hi
u can try this , please update the driver update for the same issue and update the driver for the sound device or please unistall and reinstalle the sound drivers on the system, or do systemrestore if it was working some days back .... check the
  1. Click Start , Run , and enter services.msc into the Open field. A services window opens.
  2. Scroll down the list of services and find Windows Audio.
  3. Right-click Windows Audio and select Properties .
  4. Select Automatic from the Startup type dropdown list, and click Start to start the audio service.
  5. Click OK and test for sound.
May 24, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
No sound
The Philips DVP5982 has an odd menu setup for the HDMI sound.
If you get sound from the analog outputs from the unit, but no sound when you use the HDMI output, use this procedure to see if you can restore it:
On the remote control, press Setup.
- Right cursor to the Audio Setup Page
- Go down to Digital Audio Setup
-Right cursor, to get to the screen that shows
Digital Output
LPCM Output
HDMI Audio Setup
Try to go up to the Digital Output setting- if you can't , and instead it shows only HDMI Audio Setup with the "On" highlighted in blue, this is the quirk:
Go into the HDMI Audio Setup, and select "Off", and press Enter, so it's highlighted in blue.
Now it should let you go into the Digital Output menu selection, where you may find it to be on the "Off" setting.
Select "All", and then you can go back to the HDMI Audio Setup and set it to On again, and it should now output sound from the HDMI again.
For some reason, they decided to lock out the Digital Output settings menu when the HDMI Audio is On- go figure.
So you need to turn off the HDMI sound before you turn the sound on.. ;)
Jan 12, 2008 | Philips DVP5982
HP Compaq Presario C304NR Notebook Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
