Question about Mitsubishi WS-65611 65" Rear Projection Television
Mitsubishi WS-65611 Blinking lights.
I was wondering what the board under the DM-module in a Mitsubishi WS-65611 is called and where i can get one? Also the part number would be great. Thanks
  • dfairch69 Mar 13, 2008
    Was very helpful. Thank you.
  • rocnwan1 May 26, 2008
    I have a continuious blinking lite. Will not reset. Had a power outage sometime during the night. I tried turning power off for 30 minites, no help.
    Genius:
  • 1,153 Answers
You are probably talking about the FMT board. I think you can have this board repaired at PTS 18008447871
Posted on Mar 13, 2008
SOURCE:
The tv will not turn on
If the front panel is blinking - without any pattern..your TV most likey has a DM module problem. You can get a kit from www.TvRepairKits.com
If it blinks as 2,2 pattern - its likely a convergence problem.
Apr 20, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65611 Projection TV When I turn
The problem is common to Mitsubishi projection TVs. Technicians dubbed it as the "blinking green light of death" due to its notoriety.
Here's the basic troubleshooting of the said problem.
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
If you are still having the problem, either of the following is causing the problem:
  1. DM Board Capacitors have FAILED
  2. Power supply failure
  3. EEPROM Board failure
If the capacitors are bad on the DM board, you can replace it by yourself and save a couple of bucks. The capacitors will cost you about $4 or less compared to $200 when you ask a technician to do it for you. Just insist that the 4-1000uF, 16V capacitors be replaced They usually insist to replace the DM board and cost you $500-$800. These are the capacitors on the DM board with the bulge indicating they are bad.
Same thing with the power supply. You can check the filter capacitors for this kind of problem.
Please let me know if you decide to do the repair yourself and need the guidance to do it.
Nov 30, 2009 | Televison & Video
Ws-65611 wont power on
Most likely bad caps on the dm board.
Sep 05, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi tv ws 65611 won't turn on. light keeps blinking on and off on the front panel and what is the mitsubishi customer service relation web address
the common fix for the " mitsubishi blinking green light of death " on this model is replacement of electrolytic capacitors on the "DM module board"
this is thier customer care:
telephone : 800-332-2119
E - MAIL : [email protected]
Mar 31, 2009 | Televison & Video
Blinking green light of death 1080 series
FIRST....did the TECH replace the CAPS in the DM module??
If he didn't....he's assuming the WORST case scenario and ESTIMATING for that....
In your situation, CALL a Mitsubishi Authorized Service center (God I hope this other guy wasn't one !)
I do Mitsubishi service....and it looks like the Mitsubishi Service website is presently undergoing maintenance this morning....
Otherwise, I would have priced out a NEW DM module and seen if that's what he was estimating.....
Oct 31, 2008 | Mitsubishi WS-55613 55" Rear Projection...
DM module removal
Check this link for guidance with pictures about DM board removal.
Thank you.
Oct 07, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Blinking light
You will need to repair or replace DM board
Apr 30, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65513 light blinking
If the light continuously blinks, there are four(4) caps, 10000upf @ 35v that are bad on the DM board. The board is on the right side of the chassis, looking from back, the caps will be swollen on the top. The repair is more cost effective then replacing the board.
Mar 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
307 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
