"Mechanism Error" Hi, I have a Blaupunkt 6 disc stereo unit out of a 2003 VY2 Holden Calais (Australia). I pressed the eject button to get disc 4 out and after making a few noises I got a "Mechanism Error" and the CD switched off. When I press the CD button the screen shows the cd ejecting graphic for about half a second then switches back to the radio. The back of the user manual that came with the car has three numbers on it: The first is big and in bold: "457" - I don't think this has any real relevance. The second is - "Holden Part Number: 92096457" The third is - "Bosch Part Number: " - As Blaupunkt is a sub-group of Bosch I think this might be more relevant. The picture below is pretty dark (it came from an add on ebay.com.au) but is the same as the unit from my car. Any help or advice you can offer will be greatly appreciated, so thanks in advance! Stewart
  • harrison508 Mar 13, 2008
  • harrison508 Mar 14, 2008
    The Bosch part number that should have appeared above is:
    8 622 402 490
VOTIT
  • 2071 Answers
SOURCE: I have a Denon DM35DAB
just open your remote control and clean it with an alcohol, and do some resolder works of the parts joint , maybe there are already cracked in the remote that why is not works properly..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 10, 2008
leethedeuce
  • 4472 Answers
SOURCE: My 1997 Lexus LS400 is
What is the exact error it gives you how is it spelled exactly? Once you clean everything with some computer air then I would see how it works. Then you will have to consider replacement. With mp3 technology now. There are much easier ways to go about this. It is nice to keep it stock though.
Thanks,
Lee
Posted on Oct 16, 2008
SOURCE: On LG FA 163 when trying to eject just gives error "LOCK ON"
Press "stop" for 10 second.
Posted on Dec 22, 2008
MNfisherman
  • 11896 Answers
SOURCE: CD player won't work
Firstly is it burnt or factory cd? Most factory cd players won't play a burnt disk.
If you have a store-made cd and it is not reading that, then the lens inside the player is dirty and needs to be blown out with a can of "airduster"
Posted on Feb 01, 2009
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
Posted on Feb 28, 2009
Clarion caa 397 not ejecting the cartridge
Try here: Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Aug 27, 2014 | Clarion Digital Audio/6-disc Car Cd...
My 2003 chevrolet silverado says no discs when there are discs installed
Is this a internal 6 disk changer or a external one ,if external then eject the cartridge and remove all the CDs ,now insert the cartridge and if one is jammed it should remove itself into the cartridge when you press the eject cartridge button ,well this works on my jag
Nov 30, 2013 | 2001 Mercedes-Benz C-Class
To switch itm on
look for power button or "source" button. May be labeled SRC
sometimes it takes a 2 second hold - not just a quick press.
Also could be 3/4 circle with a diagonal dash.
On this unit....
http://www.audiophile.pl/upload/Blaupunkt%20CD/BLAUPUNKT%20ALICANTE%20CD32.jpg
It is upper right button SRC
Dec 22, 2008 | Blaupunkt Alicante CD32 CD Player
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Jun 01, 2008 | Blaupunkt Car Audio & Video
Dvd dose not play
1. Insert any disc
2. Press Eject on remote (Once you eject, don’t pull the disc out)
3. Press DVD Setup on remote
4. Press 8800 on remote
5. Press DVD Setup on remote
6. Press Angle on remote
7. Region code number (0 : free, 1 : USA, 2: Europe)
8. Press (Skip Fwd) on remote.
Apr 20, 2008 | Blaupunkt IVOD-1022 Overhead LCD Monitor...
Car audio security code
pin is on the metal frame of radio on left or right side and on sticker starting with the letters BP- then your 4 dig pin also the radio code after the pin write it down to. swich your radio off press hold the AS button while holding AS button down press power button it will automaticaly ask for security code enter security code then radio code
Feb 22, 2008 | Blaupunkt PCA250 Car Audio Amplifier
5 cd incar stereo
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Dec 13, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
356 people viewed this question
 Grubhead
Grubhead
