Question about Panasonic KX-TGA101S Cordless Handset
Uniden DECT 6.0 2080-2 rings for no reason
My Uniden 2080-2 rings once at differnet time intervals (no set pattern) from every 10 minutes to once every several hours with no incomming call. I can even go a whole day or night without it ringing. It is just one phantom ring every once in a while. I do not have any of those extra caller ID or voice mail type services. I cannot find a solution in the manual. Is there a way I can make it stop?
Thank you!
Erick
I have the same problem as eaho's, only with a Panasonic DECT 6 KX-TGA101S. Any help would be greatly appreciated.
Conan
  • 1 more comment
  • Anonymous Apr 11, 2008
    I have the same problem where the Uniden Dect 2060 6.0 seems to get phantom rings every so often.
  • Anonymous Mar 14, 2014
    how to change number of rings from 2 to 6
  • Anonymous Mar 26, 2014
    after replacing battry ituly carged butcannotuse e menu completely cause it will not arrow to the correct area. cannot checkcaller id cannot change ringtone
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Posted on Apr 24, 2008
  • donotspamme Oct 05, 2010
    Our DECT 6.0 phone rings once exactly every 15 minutes and there are no other cordless mobiles within 150 metres of us. We are on a campus. Certainly no phone is being used exactly every 15 minutes. We had the same issue at the same interval over a year ago in a different building with a different phone and resolved it by using a different type of cordless phone. Our phone system is spread across a few campuses and uses extension numbers.
  • anoyedbydect Oct 05, 2010
    Ok. We found the solution at work. We had to change a setting on the extension on our Phone Switch, Avaya G3R. We unchecked the Test selection on the phone extension and the phantom phone rings went away. If you don't have a local phone switch then you need to call your local provider, most likely AT
SOURCE:
HOW DO YOU RESET ANSWERING MACHINE ON 6.0 UNIDEN PHONE
Answering Machine - Uniden Support
unidensupport.com/AnsweringMachine
Get support for your Uniden Answering Machine. ... For models that have an */envelope key on the handset: ... How To Change The Record Time & Ring Time.
Customer Support
mycusthelp.net/UNIDEN/_cs/AnswerDetail.aspx?sSessionID=&aid=270585 How Do I Set The Greeting On My DECT 6.0 Cordless Phone Answering System? Question: Answer: To record your greeting on the DECT Single-Line Models, please do the following: 1. ... features your model may have can also be found in your owner's manual. ... http://www.uniden.com/index/manuals_results.cfm?cat=1
I have a Uniden phone/answering machine, DECT 6.0, number ...
www.justanswer.com > Electronics Question > Phone Problems I have a Uniden phone/answering machine, DECT 6.0, number BK20033715. I purchased it about a year ago. I need to change the message on the answering ...
[PDF]owner's manual - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7955_1_OM.pdf Terminology used in this Manual . ... Answering Machine Features . ..... change global settings at a time, and you have to make sure the phone is not currently ...
Owner's Manuals - Uniden
https://www.uniden.com/product-information/owners-manuals Owner's Manual. Search for an Owner's Manual. The product name/model number is on the product's ID label on the back, bottom or in the battery compartment ..
RESET ANSWERING MACHINE ON 6 0 UNIDEN PHONE Google Search
Apr 20, 2017 | Uniden Lands Phones
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Uniden dect 6.0 set number of rings before answering machine comes on
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jan 03, 2013 | Uniden DECT 6.0 Cordless Phone ID
How to set # of rings of answer machine on a dcet 6.0 Uninnden cordless
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 24, 2012 | Uniden Lands Phones
Phone only rings once then goes to greeting
This phone has one mode to configurate the "number of the rings" you need to programer this "time" Enter to this option always search as inside "MENU" follow your user manual also.
Jun 27, 2012 | Uniden DECT1560 DECT 6.0 Expandable...
How to you set number of rings for Uniden 6.0
To set the no. of rings for a Uniden D1680 or similar, try this:
1. Press [menu]
2. Scroll down to 'Answ Setup', press [select] or [ok]
3. Scroll down to 'Ring Time', press [select] or [ok]
4. Scroll down to highlight your choice, '2 Rings', '4 Rings', etc.
5. Press [back] or [off]
Apr 26, 2012 | Uniden DECT 6.0 Cordless Phone ID
Would like to increase number of rings before answering machine comes on.
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
One ring - noise like fax to caller, phantom call to receiver
Try unplugging all sets and call in. Do you still have a faxlike tone, like from an ALARM system or something else down the street?
Aug 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
My roommate lost his manual for his 6.0 cordless phone system
Since you declined to specify the model of his Uniden DECT 6.0 system I can only suggest you (or he) select it from the list beginning here to download a copy of the manual.
Dec 04, 2008 | Uniden DECT 6.0 Cordless Telephone...
Panasonic KX-TGA101S Cordless Handset Logo
1,128 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
