Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Mitsubishi Mod # WS-55315
The power-on/timer led on front panel flashes when tv is off. Tv seems to work ok.
  • kandykrazy May 10, 2008
    We are trying to hook up our digital cable box to our tv but we do not have the insruction manual for the tv. Can some one please assist with placing the cabl wires corectly?
    Scholar:
  • 104 Answers
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Posted on Mar 13, 2008
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
The power went out yesterday. When came back on couldnt turn tv on. The timer indicator on front of tv is flashing green and I dont know how to reset. Can you help? The tv is WS-73711
Thats a very common problem caused by weak capacitors on the DM board. When power is lost the caps discharge and when the power is restored they cannot recharge so the timer led will blink non stop. You can get the DM repair kit for your model from www.tvrepairworld.com it contains the upgraded capacitors and the CD with repair instructions.
Jun 06, 2011 | Mitsubishi WS-73711 73" Rear Projection...
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Nov 06, 2010 | Mitsubishi WS-55315 55" Rear Projection...
The power went off and when it came back on the tv wouldnt come on but the timer light is lit
First thing is to unplug the TV for several minutes, replug, Power LED shouls flash for around 90 seconds then go off. Try to power up then.
If the power LED does not stop flashing , or the TV will not turn on still, it will need a repairman.
Oct 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi ws 55315 and i need to program my remote to the att uverse motorola cable box.
hi i have a couple of codes here for your mitsubishi tv just try them 0005 0151 0051 0004 0009 0254 0022 0141 0180. hope this would help! goodluck!
Sep 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Protector glass on a mitsubishi 55in hdtv 1080 #ws-55315
I have the same tv and I took my clear shield off and never put it back on.  The picture is much better without it as it will reflect light and objects in the room making it difficult to see the pic clearly.  I was told by a service tech that the primary purpose of the glass or shield is to prevent damage to the screen from objects, water etc.  If you have no small children in the home you can enjoy a better pic.
Dec 26, 2008 | Mitsubishi WS-55315 55" Rear Projection...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
My ws-55315
Good Day afsho;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C.
good luck, big irish.
Jun 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
