Question about Samsung SCX 4521F All-In-One Laser Printer
Copy size When I make a copy (not a printout) the size of the copy is shrinked to the size of an envelope. The paper size is A4 and the copy @ 100% Please help
  • asv0307 Oct 29, 2008
    My copies do the same, scanning is fine but when a copy is made it squashes the copy to the left side of the page and blank on the right side. How do I set my printer up to make correct copies.
  • blanosulxxl Apr 21, 2009
    I have the same problem! The devive shrink whole documents to one half A4 page!
    Sergeant:
  • Samsung Expert
  • 406 Answers
Please let me know If you make a scan. The Output its same as in the hard copy or Shrinked. If its shrink then its problem from scanner. Needs a setup. Else Refer back to me.
Posted on Mar 13, 2008
Printer will ask did you load the correct paper or envelope? I touch yes or no and it displays: copy does not support envelope #10. Load a supported size of paper in the tray to continue.
If you are trying to use #10 envelopes and your printer says it does not support that size, you'll need to try a different size envelope--one that the printer supports. Consult the owner's manual.
Apr 21, 2016 | Office Equipment & Supplies
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Jul 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
How to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
  1. Press <Menu>.
  1. Press <Menu>.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Printing Envelopes
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 13, 2007 | Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
118 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
