Question about Fargo 4250 Thermal Printer
Fargo 4250 Touble finding drivers and software for Windows Vista
Can anyone be of some assistance to help me find some drivers and software for the Fargo 4250 Card Printer to install on my Windows Vista System.
  • 2 more comments
  • debz0123 Jul 02, 2008
    me do i need urgently !!! can anyone help please?
  • Anonymous Sep 10, 2008
    Another one needing!
  • securityman8 Feb 17, 2009
    As far as I have been told there is NO Fargo Printer Drivers for Vista. Is this correct?
  • Anonymous May 21, 2009
    wait for someone help:thank
    Problem Solver:
  • 10 Answers
The 4250 has been out of production for a long time Fargo does not make Vista drivers for it. you could try to download the most recent drivers and run them in compatibility mode.
Posted on Sep 16, 2009
    Problem Solver:
  • 5 Answers
This printer has been discontinued for too many years, therefore there are no drivers available for Vista, nor will there ever be as even Fargo has discontinued support for this printer model.
Posted on Jul 20, 2009
  • 526 Answers
They dont make vista drivers for the 4250
Posted on Apr 17, 2009
SOURCE:
Got xp windows, cannot find drivers for fargo printer 4250
Hi there,Due to the age of the printer you only get NT/2000 drivers. You can download them at the site below it also has a guide on how to install. The drivers for NT/2000 should work with XP. You can even try the 98 Drivers.http://www.fargosupport.com/archive_results.asp?archDriver=1&archPrinter=13&archSubmit.x=39&archSubmit.y=6&archSubmit=archSubmit
Regards,
Jul 26, 2011 | Fargo 4250 Thermal Printer
I have bought a Fargo Pro LD Thermal printer, and have a windows xp desktop and a windows vista laptop. My problem is the driver that came with the printer is for windows 98. How do i go with instaliing...
The support options seem to be limited. However, I found an Win2K and XP driver here: http://drivers.softpedia.com/get/PRINTER/OTHERS/Fargo-Pro-L-Printer-Driver-202.shtml . Click on the Download button on the left and then click on the download from External Mirror link.
For Vista, you may find the Compatibility option works. Right click on the file you downloaded (after unzipping if it ends in .zip, find an .exe file in this case) and choose Properties. Then click on the Compatibility tab. Set that up to run the program as XP. Then right click on the file again and choose Run as Administrator.
I hope this helps.
(my anti-virus software hasn't flagged this site or file as a problem; however you may want to check further for malware.)
Nov 14, 2010 | Fargo Pro L ID Thermal Printer
Drivers for Vista Fargo 4250 thermal printer
Hi
Here is a list of drivers for the Fargo 4250:
http://www.fargosupport.com/archive_results.asp?archDriver=1&archPrinter=13&archSubmit.x=23&archSubmit.y=6&archSubmit=archSubmit
Please bear in mind that this is an old printer, therefore fargo have not made any drivers for windows vista. You could download the NT/2000 drivers or the ME drivers and run them in compatibility mode.
Regards
Mike
May 26, 2010 | Fargo 4250 Thermal Printer
Fargo 4250 operational and service manual wanted please.
Hope this helps.
http://rds.yahoo.com/_ylt=A0geu9vVQ6ZJ0FIAS2tXNyoA;_ylu=X3oDMTEydWZ1ZTJhBHNlYwNzcgRwb3MDMgRjb2xvA2FjMgR2dGlkA0gyNjlfOTg-/SIG=12gbeasbg/EXP=1235719509/**http%3a//www.e-scan.com/pdf/Fargo%25204250-4225%2520manual.pdf
Feb 26, 2009 | Fargo 4250 Thermal Printer
FARGO 4250 DRIVERS NEEDED!
They only have drivers up to NT and Win2KPro. Try using the driver in compatibility mode.
Good luck.
Feb 04, 2009 | Fargo 4250 Thermal Printer
Need Windows Vista driver for Persona C30
Try Downloading this (it's the installer/Setup Application for the XP Driver version)
If you don't trust me, Go to their website and Download the same file there.
I'm an Expert Driver Finder, and even I couldn't find the Vista Driver..
  • Anyways, Right-Click on the Setup file and select ->properties.
  • Then click on the compatibility tab, and select Run this program in compatibility mode for: Select WindowsXP (sevice pack 2).
  • Then click OK to exit the properties screen. And run the setup program, I think that shoul be it.
I Hope This Helps.
Reply back/Add a comment if this works out okay.
Jan 27, 2009 | Fargo Persona C30 Thermal Card Printer
Fargo pro l
they dont make vista drivers for the pro-l
Aug 29, 2008 | Fargo Pro L ID Thermal Printer
Resurrecting dead Fargo 4250
it sounds like you have a bad main board again. you might be having some power issues.
we are an ASC for Fargo, if you need parts send me an email. Although the 4250 has been discontinued a long time ago, parts are scarce.
Aug 16, 2008 | Fargo 4250 Thermal Printer
Fargo 4250 driver
You could try to install the XP drivers by running them in compatibility mode on Vista. It might work
May 05, 2008 | Fargo 4250 Thermal Printer
Fargo 4250 in XP
Download the Windows 2000 driver. Go to "Settings" then to "Control Panel". Then go into "Printers and Faxes". On the left hand side click "Add a Printer". Check "Local Printer attached..." but make sure "autmatically detect..." is not checked. Then click next. Select the port that the printer is connected to. Then click next and it will ask for the software. Click "Have Disk" and browse to the folder where you saved the driver. It should then find the Fargo 4250 driver and your in business.
Dec 04, 2007 | Fargo 4250 Thermal Printer
Fargo 4250 Thermal Printer Logo
622 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Altin S1
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
