Question about Adobe Illustrator
How it create log file in adobe illustrator
How to create log file or text file of our work in adobe illustrator?
  • Milind Dixit Apr 14, 2008
    yes i am stll waiting to solve this problem
SOURCE: Flash File Overall Color and Contrast too light
Posted on Sep 28, 2007
  • 265 Answers
SOURCE: Adobe illustartor shows run time error
How large is the file? How much system memory do you have? What is the source of the file? Are you able to open the file on a different computer?
Posted on Dec 15, 2007
  • 265 Answers
SOURCE: converting text to an object
Select the type object (the Select tool must be used, not the type tool); then from the menu, choose: "Type," then, "Create Outlines." The text will become an object, with multiple lines and curves, fully editable, by each point or line.
Posted on May 10, 2008
SOURCE: adobe illustrator
Hi Mekarim,
You may try this:
1. Open the C:\Program Files\Common Files\Adobe folder and look for a folder starting with Type and meaning Type support; in 10 it is called TypeSpt;
2. Create a namesake folder on your Desktop;
3. Move all the contents to the namesake folder.
Please report back, including the name of the folder.
00971 50 2511165
Posted on Aug 17, 2008
SOURCE: Adobe Acrobat Pro/Adobe Illustrator
Open the file in Illustrator and "Flatten" the layers this combine them into one layer, and will give you a flat PDF
Posted on Jun 01, 2009
I very much like to work with graphic things
How to repair ai file?Place the damaged Illustrator file in a new Illustrator file.
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
  1. In Illustrator, choose File > New.
  2. Select the appropriate size and color mode, and then click OK.
  3. Choose File > Place.
  4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
  5. Name and save the file.
How to recover corrupted ai file of Adobe Illustrator
Feb 14, 2018 | Adobe Computers & Internet
View content of Illustrator?
Download and test third-part software for recovery illustrator documents like a Illustrator Recovery Toolbox from
Please follow instructions if you if you want to try to recover the file itself. :
1. Check a size of file. If it smaller then 50K then projects are empty
2. Attempt to re-create files as describe here:
Sep 11, 2016 | Adobe Computers & Internet
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
Dec 15, 2014 | Adobe Illustrator CS3 - Windows for PC...
Adobe illustrator file corruption. What to do?
First check your illustrator. Could it open other files or not? Try to create new file and save it, then open again.
Try to open your corrupted file on another PC. Then if it doesn't work, it means that your file is corrupted. So you should try to restore it by Recovery Toolbox for Illustrator . You can download it here
Also you can read here about corrupted file recovery:
Nov 18, 2014 | Adobe Illustrator CS3 - Windows for PC...
What should i do to open all files created in illustrator cs to illustrator 10?
first open all file in CS. then, select SAVE AS. save it to another folder. then a box will appear. select adobe illutrator 10 fron the VERSION BOX located at the uppermost part of that box. now you can open the file in illustrator 10. good luck!
Apr 12, 2011 | Adobe Illustrator 10.0 for PC
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Converting text to an object
May 09, 2008 | Adobe Illustrator CS V11.0 for PC
Computers & Internet Logo
194 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
