Question about HP Compaq nc6000 Notebook
Monitor problems My monitor has gone very dark after I bumped the computer. I can barely see it so have to use an external monitor. Is there somethign in the seeting that I can change or does it need opeing up for a repair?
  • gberrich Jul 21, 2008
    Compaq nc6000. backlight problem. can very fainly see the images on the screem. On boot up you get the first screen in orange and then everything goes very dim. Have taken out the battery and CD-ROM drive and left powered off. Powered up and same problem. Not taken the laptop apart yet ro look for any loose connections on the inverter (if I can find it). Thanks.
    Genius:
  • 1,027 Answers
It sounds like the inverter or backlights have gone bad. When the inverter board goes bad it quits sending the required voltage to the backlights. The backlights illuminate the screen. It may just be a loose connection, If you need an inverter you can try E-bay but I order from businesses like. http://www.impactcomputers.com/344396-001-ib.html
Posted on Mar 13, 2008
Charging and monitor issues
If your AC Adapter and Power Cord is working fine, then your new battery has a problem if it will not charge. Just because it is new does not mean it will work.
As for your Monitor, try the steps below. Because it works with an external monitor, we know your Video Card is working fine, so the problem is either the LCD Inverter or the Lcd Screen itself is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell XPS 1530-146P (X1530-146P) PC...
No display
No Display? Does it seem like the computer is running but the screen is black? Do you hear fans, disk drive spinning, lights?
If the computer seems like it when through the boot process and is up and running but the screen is black, then you either have a Video Card problem, LCD Inverter problem or the LCD Screen has gone bad.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 19, 2012 | Samsung Computers & Internet
My screen on my Dell Inspiron Notebook went black. But I can barely see on the screen that the computer ran a problem check and said my computer was having a problem starting.
The invertor lamp has gone bad, so you would need to replace the LCD screen. there is nothing else you can do. try to connect an external monitor adn then press Fn + F8 to switch the video to the external monitor. if the image on the external monitor is fine then its the lcd. if the external monitor has the same image then motherboard problem. you can also try Fn + Up arrow key to increase the brightness.
Oct 16, 2009 | Dell Inspiron 1000 Notebook
My computer monitor will not display properly
this is the first way. use external monitor. if you get clear view then you have a problem with LCD INVERTOR (you say bulb).
i hope it works.
May 27, 2009 | Gateway M-6307 Notebook PC
Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Dell Inspiron 6000 Notebook
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Usually every laptop has the option of adjusting the screen brightness as you would want the screen to be pretty dim when running on battery to conserve battery life.
First thing to check would be just that.
Dec 11, 2007 | Apple Colorsync 850 Monitor
HP Compaq nc6000 Notebook Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
