Question about Fuji FinePix A500 Digital Camera
Digital camera headache
Read error and card error displaying - can't delete image or take image
  • melsgrls Apr 08, 2008
    My daughter took the memory card out of the camera to upload some pics
    to the computer and when she put the card back into the camera now when
    you turn it on it says "Card Not Initialized" and I can't take any pics, look at
    other pics or do anything.
    Can you please HELP?!!!
    Thanks
    Melissa M.
    Master:
  • 619 Answers
Hi , hook to computer and scan with anti virus ./
Posted on Mar 13, 2008
I cannot erase a full memory card
The manual says: It may take a long time to delete a lot of images by selecting [All images]. It is recommended that you delete images on a computer or format the recording medium using the camera. on page 88.
You also should read item 6 on "read this first" about the memory card.
If pictures are protected, you can't delete them in the camera.
Oct 30, 2013 | Sony Alpha DSLR-A100 Digital Camera
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
I connected my cable to transfer pictures from my canon 100 ixus but it showed connection error. What does it means?
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd780_is#ServiceAndSupport
Troubleshooting the camera displaying Communication Error when connected to the computer via USB. If the camera displays "Communication Error," when trying to download images the main cause for this error is that there are more than 1000 images stored on the memory card. It is recommended if there are more than 1000 images on the memory card, that you use a card reader to acquire the images, or to delete images off of the memory so that there are less than 1000 images to download from the memory card.
If this is not the case, there are not 1000 or more images on the memory card, try reconnecting the camera to abnother port on the computer, try another cable or another computer. This error can also display when connecting to a direct print printer. Please check with the printer manufacturer for more information on this error.
Jul 31, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Can't connect camera to computer (Windows XP)
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see the following post, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive. Just make sure you get one that's stated capable of reading your S200's CF card.:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Feb 21, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Deleted images w/o pressing delete
It sounds like you reformatted the disk - this deletes all the files on the disk.
Here are several image recovery programs that can often recover images after a disk has been reformatted.
File Rescue
Disk Doctors
Uneraser
Data Rescue
You can download trial versions of these programs, and test to see ifthe program can find your images, but have to pay to register thesoftware before it will actually recover the images.
You may also need to use a card reader to read the data from the card, rather than read the card while it's in the camera connected to your computer. Card readers are relatively inexpensive (less than $20) and can be bought at most camera and computer stores.
Dec 28, 2008 | Samsung NV3 Digital Camera
Camera wont transfer images to laptop
Sep 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Read error
try using the "format" option from the set-up menu. That should wipe everything off the card, and get rid of any "bad" data that has accumulated over time. If you want to only erase selected images, try the erase option again, but make sure to wait until the green light comes on before proceeding.
Jan 14, 2008 | Fuji FinePix V10 Digital Camera
Picture Error
that particular image corrupted through not deleting properly. What to do? 1. Reformat the card in camera and sacrifice the images. 2. download recovery software and try to pull stuff off the card then reformat. download recovery software from www.pcinspector.co. or www.konvar.com.
May 15, 2007 | Olympus Camedia C-180 Digital Camera
Fuji FinePix A500 Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
