Visual Basic Problum
How the Microsoft Jet Engine works with DAO.
Autocad 2006,1utocad 2007 very slow with 1 gb memmory.so pls say me that how speed increase in autocad 2006 and autocad 2007.
Posted on Mar 13, 2008
SOURCE:
I dont know the disadvantages of visual basic.
visual basic, is only a basic programming language, most programs will run on Java script, microsoft is visual basic though, but it uses a lot more complex scripts then, if you like the programing language, go for it, but i did not like it.
Also
VB is undoubtedly the simplest and easiest platform to build major Windows applications. The problem is that like other Microsoft products they change faster than I change my socks.You will certainly need more than just VB. Get into server and client side scripting and the use of VB Net.
Jul 06, 2010 | Microsoft Visual Basic V6.0 Fundamentals...
Visual Basic 6.0 for PC: how can I download visual c++? ...
Microsoft provides basic C++, C# and VBASIC on express editions. For software development for publication, you will need to purchase Visual Studio.
May 14, 2010 | Microsoft Visual Basic 6.0 for PC
How to download microsoft visual basic 6.0
Hi.
Microsoft Visual basic is not a free download.
The best complete application to program in Visual basic is Visual Studio. You can download it here: Visual Basic Downloads.
If you want to download the service pack required to run VB applications see here:Download details: Visual Basic 6.0.
See also:Microsoft Visual Basic 6.0 downloads.
Regards.
May 02, 2010 | Microsoft Visual Basic 6.0 for PC
I cannot load some programmes. I get an error 429 activex component message., Is there a free vista available to run over the top to fix any or all problems i might have on my system
cause : This issue can occur when DAO dynamic-link library (DLL) files are mismatched or when there are incorrect registry entries. This issue can also occur when there is a missing DAO design-time licensing key. This key is required by Microsoft Excel, but is not required by applications created with Visual Basic
Method 1 loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regsvr.exe.
  3. Re-register DAO350.dll.
    NOTE: You can obtain a copy of DAO350.dll at the following FTP address: ftp://ftp.microsoft.com/softlib/mslfiles/ To register DAO350.dll, follow these steps:
    2. In the Open box, type Regsvr32.exe C:\progra~1\common~1\micros~1\dao\dao350.dll
    3. Click OK.
  4. Click Start, point to Settings, and then click Control Panel.
  5. Click Add/Remove Programs.
  6. Insert your Microsoft Office 97 CD, and then click Uninstall.
  7. Delete the DAO folder from the hard drive.
  8. Click Start, point to Settings, and then click Control Panel.
  9. Click Add/Remove Programs.
  10. Insert your Office 97 CD, and then click Install.
  11. Repeat steps 4 through 6 to uninstall Office 97.
  12. Click Start, and then click Run.
  13. In the Open box, type eraser97.exe. (This file is also available at ftp://ftp.microsoft.com/softlib/mslfiles/.)
  14. Repeat steps 4 through 6.
  15. Repeat steps 8 through 10 to reinstall Office 97.
Please Rate Solution!
Sep 08, 2009 | Computers & Internet
Example sorurce code for database
Hello my friend try this code: This code is design for Visual Basic 6.0
Function for Connection and recordset string.  '========Connection String====== Public Sub connection(ByRef dConnection As ADODB.connection, ByVal dLocation As String)     dConnection.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dLocation & ";Persist Security Info=False;" End Sub '======End of Connection String======
'=======Recordset String=========== Public Sub recordset(ByRef sRecordset As ADODB.recordset, ByRef sConnection As ADODB.connection, ByVal sSQl As String) With sRecordset .CursorLocation = adUseClient .Open sSQl, sConnection, adOpenKeyset, adLockOptimistic End With End Sub '======End Recordset String========
How to apply the above function? Application:
'====== Command Save Button======== Private Sub cmdsave_Click() Dim cn3 As New ADODB.connection Dim rs3 As New ADODB.recordset
Call connection(cn3, App.Path & "\CASGC.mdb") Call recordset(rs3, cn3, "Select * from Debtor_Creditor_Account") Set dtglobal.DataSource = rs3.DataSource
With rs3   .AddNew   .Fields("Code") = txtCode.Text   .Fields("Description") = txtDescription.Text   .Fields("Tag") = cbotag.Text   .Update   .Requery    End With   MsgBox "New Account has been Added", vbInformation   Set cn3 = Nothing Set rs3 = Nothing
End Sub '=======end of Command Save button=====
The advantage of using this code is setting your database connection is you have a reliable connection towards your database where ever you place your database you can you don't to remount you databse connection control. Also you are no longer need to use a ADO control or DAO control just copy the function and paste it in your coding area and call the function and you have now a working database and recordset connection string.
For more details regarding how to apply this code just email me at this address: [email protected] to get more codes. thanks.. Please rate this Solution.
Jul 08, 2009 | Microsoft Visual Basic 6.0 for PC
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
"Password=mssql_password;"
Apr 22, 2009 | Microsoft Visual Basic 6.0 for PC
Installing QV 7 produces warning MS DAO preventing installation.
I,too, have the problem of installing my Quickverse 7 on my computer with Vista. What do i do to stop the running of Microsoft DAO?
Apr 08, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
Inserting data into MSFlexGrid control from an excel file
Have you tried implementing an ADO (Active Data Object) control (available from the toolbox)? Properly configured (and run via OLEDB or Microsoft Jet as appropriate for your setup) it works like a champ.
Feb 10, 2009 | Microsoft Visual Basic Enterprise Edition...
Open Questions:
-\&;-BOX Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This box USA phone number is ranked #2 out of 2 because 7,728 box USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the box USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, box USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. box USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact box USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling box USA Calling box USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from box USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with box USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare box USA's phone numbers against each other. Contacting box USA in General While I8OO8280294 is box USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach box USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact box USA.
Oct 16, 2019 | Best Computers & Internet
-\&;-WINDSTREAM Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This windstream USA phone number is ranked #2 out of 2 because 7,728 windstream USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the windstream USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, windstream USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. windstream USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact windstream USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling windstream USA Calling windstream USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from windstream USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with windstream USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare windstream USA's phone numbers against each other. Contacting windstream USA in General While I8OO8280294 is windstream USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach windstream USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact windstream USA.
Computers & Internet Logo
46 people viewed this question
Ekse
Alun Cox
