Question about Kenwood KDC-4005
How do I adjust the time
Just got a vehicle with the KDC4005 and I cannot figure out how to set the time. Any help would be appreciated. Thanks!
I solved the riddle of setting the time. I will be more than happy to share the secret if you do not have a users manual. All you have to do is send me a check for....... nah, just kidding, I am not a greedy person. Feel free to contact me at [email protected] and I would be more than happy to tell you how to set the time.
Posted on Mar 15, 2008
6ya staff
SOURCE:
Adjust shutter speed
Sometimes, some digital camreas dont allow set the shutter on multi-shoot mode; I suggest check this details on X500 User Guide.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 23, 2012 | GE X500 Digital Camera
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
I did not get any instructions with my son's ben10 four arms projection alarm clock, and cant figure out how to even set the time, does anyone have instructions please
Hi
Hopefully you've figured this out by now, but if not then I hope this helps.
Alarm Setting - Press Mode twice to change the alarm time. Set switches between hour and minutes and Adjust changes the time. The alarm is on when there is a symbol at the top right on the display. Press and hold Set then press Adjust to toggle the alarm on or off.
Time/Date Setting - Press Mode three times to change the current date/time. Use Set to move between the hour, minutes etc and Adjust to change them, as with the alarm.
Pressing Mode once accesses a stopwatch function. Adjust to start/stop and Set to clear.
Dec 25, 2010 | Toys
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
Cannot figure out if the radio is switched on.
only atomic clocks are self adjusting .
Oct 29, 2017 | Watches
Timing specs cannot figure out how to set timing
THE TIMING SHOULD BE 15 DEGREES BTDC +OR- 8 DEGREES.U CAN NOT ADJUST THE TIMING IF IT OUT OF SPEC. THEN U HAVE A TIMING BELT ISSUE OR A PROBLEM W/ THE IGNITION CONTROL SYSTEM.THE VEHICLE COMPUTER CONTROLS TIMING
Apr 21, 2009 | 1998 Subaru Forester
How to set the alarm?
Just answered this question for someone else so I thought I would just copy and paste my response.
Now sure if you are still looking for a solution or not but just came across your problem. The lower right-hand button, the one used to turn the alarm off and on, can actually be pulled out to set the alarm. Pull out the knob, adjust the alarm time, push back in and push one more time to actually set the alarm. Hope this helps.
Dec 31, 2008 | Citizen Calibre 2100 AV0031-59A Wrist...
How to adjust time
good morning ! to set your baby g casio watch , press the adjust button to make digit blinking when the digit blinking you can chagne the digit press the mode button,and next use the two to chagne digit after seting press the adjust button and the time is gona be normal,thanks po !..
Sep 05, 2008 | Casio Baby-G BG169-2V Wrist Watch
Reset my G Shock watch
try http://forums.watchuseek.com/forumdisplay.php?f=17
seems pretty extensive.
you either need to set your time manually if you are not automatically receiving the atomic signal. if you are receiving the signal, then either you are not in auto DST mode or your home city is set incorrectly.
Nov 08, 2007 | Watches
Car Audio & Video Logo
123 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
