Question about Crown CE1000 2-Channel Amplifier
Bridged So do I need an adapter to run this in bridged mode?
    Champion:
    New Friend:
  • Crown Expert
  • 232 Answers
No...
Posted on Dec 16, 2014
  • 682 Answers
Setup of bridge mono mode:-1-turn your amplifier off.2-connect input wiring to channel(1) input--3-connect speaker across positive outputs terminals-do not use negative terminal when amplifier is operating in bridge mono mode.4-turn down (fully counter clockwise)of channel (2).
Posted on Mar 13, 2008
SOURCE:
I accidentally used the two outs (A & B) at turning on the pmp 5000 in the bridge mode. The mixer was normal during the first 10 minutes, then the mixer shut down and stop working, and now it doesn't...
Insufficient information ! Were you using a special cable used for bridged mode or used regular cables and just changed the slide switch to bridged mode? IF you had regular cables for A/B and just had the switch to the bridged mode NO DAMAGE WOULD RESULT. The bridged mode switch really only sets both amps to be driven from the same mixing buss as monaural. If you had a bridged cable and a plain one you would have overloaded one side amp. The amps have an "electronic" over current fuse and if you trip it you have to leave the power off for a minute or so and then re-power the amp. There is a HAZARD that I have written a tip in Fixya about PMP mixers. The sleeve of a 1/4 inch plug connected to side A is the HOT signal out of the amp as opposed to the B channel being the tip of the 1/4 inch plug...this assumes you might be using Speakon to 1/4 inch speaker cables. DO NOT under any circumstances use Speakon to 1/4 inch adapter cables as the barrel of the adapter female part on channel A is HOT to ground and you will pop the A amp.!!!! I am afraid that if you were using regular cables taht another failure occurred not related to the setting to bridged mode. The speaker leads for bridged mode are configured by the way the special bridged mode Speakon cable is wired... The slide switch only configures where the amps get there audio be it stereo busses or singly from one side. If after being off for a few minutes the amp still is totally dead, check the main power fuse which is alongside the power input connection in a plastic boat you pull out. IF THE FUSE IS BLOWN do NOT replace it as it will likely cause additional damage. Have unit repaired. There is a weak spot in these that results in arcing between layers of a multi-layer circuit board.
Apr 15, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Wireless adapter stoped recieving internet and will not connect
>If you have a Modem, aside from that router, the modem might no longer be on bridged mode, which is required to make the router function
>check it... if that's the case give your internet service provider a call and have them set your modem to bridged mode and connect the router, since nothing was changed on the router it should be able to detect internet signals rightaway ?
>comments suggestions ratings and violent reactions will greatly be appreciated
Sep 24, 2010 | NetGear WG111T 802.11g/b (E82321) Wireless...
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Can you help me please??
you need to setup a network bridge between the tower pc and the xbox 360
Select Control Panel/Network Connections and while hovering over Network Connections, right click and choose Open. This will open a panel that should list your network connections.
This image shows all my existing network connections. Yours may not have the same adapters. The two adapters that matter are your wireless adapter and your Ethernet adapter. They will have different names than mine because I have renamed them from their default values. I have highlighted the two adapters in the graphic below.
Step 2 If you have both Ethernet and wireless adapters (and you must in order for this to work), then both of them will be listed in the Network Connections panel. Using the ctrl-click selection method or the drag-area method, select both adapters.
Step 3 Right-click one of the adapters and select the Bridge Connections option.
Step 4 You will see a notification that the bridge is being built. This may take a few moments.
Step 5 Once the bridge is complete, you will see the bridge icon and the network adapters as shown below:
Step 6 The bridge is only partially complete at this point. To complete the configuration, you need to relate the network adapters to the bridge. I’m not exactly sure why this is because you have to select the adapters to create the bridge in the first place. This is my first bridge, so it’s possible there is a better way of doing it. But this process has worked for me. If you know of a more concise way of configuring the bridge, let me know and I’ll update the process.
In any case, select the bridge, right-click and select Properties:
Step 7 In the Properties dialog, put check marks in the network adapters that you want to bridge. Make sure you select the wireless and Ethernet adapters.
Step 8 Now, the bridge is complete. It will take a few moments for your laptop to finish the configuration, get a new DHCP lease and complete the connections.
To verify if your bridge works, connect the XBox 360 to your laptop’s Ethernet port and connect with XBox Live.
Dec 10, 2008 | Microsoft Xbox 360 Console
How to put dsl-320T in full bridge mode?
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
May 18, 2008 | D-Link Computers & Internet
ZyXEL Ethernet Bridge Won't Connect
the i =ndications are quite clear it's a concern with router's wireless reception...try to reconfig wireless settings on your router change channel to 1 if still the same router is not sending wireless signals properly..
Feb 13, 2008 | Computers & Internet
Yamaha P4500 Power Amplifier 2-Channel Bridge mode
im from Yamaha service before and i know this model can handle as low as 2ohms per channel. I have to check on my manuals though if bridged. i dont see any reason why it cant. and it has a bridge option input stage... let me get back to you again in the days to come.
or email me [email protected]
i have a service manual to check on this. got to dig on my closets..
Mar 14, 2007 | Yamaha P4500 Power Amplifier 2-Channel
Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Crown CE1000 2-Channel Amplifier Logo
862 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
