Wireless connection Hi I have a Sahara laptop, I cant connect it on wireless. I went to control panel and I cant find anything related to wireless. Please help
  • DonnaPet Jun 03, 2008
    Can't connect to wireless network
  • 58 Answers
It would be in network connections folder.Highlight the wireless connection in the right pane then in the left pane click on repair
Posted on Mar 25, 2008
6ya staff
SOURCE:
Sahara laptop image book
Reinstall the wireless drivers
(Download AND install)
http://www.sahara.co.za/DriversAndDownloads.php
Regards,
joecoolvette
Apr 30, 2013 | Computers & Internet
Please help me get my wireless settings
If you have windows XP on the laptop then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. In the preferred network box, Select all SSID and remove the name from the list. Once the list is empty, Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista on the laptop:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa
rating. If you cannot rate this post with the highest rating, then please
comment to this post and I will try to help you further.
Regards
Anand
Aug 30, 2009 | Acer Aspire 3000 Notebook
Wireless Connection
1. go to Start->control panel->network connections->wireless connection. 2. There you will find an option of repairing the wireless connection. select it and repair your connection.
Aug 30, 2009 | Acer Aspire 4315 Notebook
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
Wireless connection
Hi Kazmerr
Re: Dell Latitude d600
Assuming you already turned your wireless, your distance should be in range fom your router. Turn off and on the switch  or you can press Fn+F2 to start your wireless connection.If thats a no go check your wireless client  and make sure no other wireless client is installed ie. your ISP wireless connection manager.
Other work around for this is : make sure you have enabled or started your wireless client for windows by ff the steps below :
Win XP Sp2: start > control panel  classic view> administrative tools > services > then look for Wireless Zero Configuration and right click it and choose start or restart . After doing this you may check or view your available wireless network again.IF no go >
For winXP or VIsta ONLY
Go to start > control panel   { classic view } > system > device manager > Look for network adapter {+} sign > look for 802.11g wireless / or anything that says 'wireless' and make sure that theres no yellow question or excamation mark on it and IF none right click it and choose remove/uninstall> then restart PC > and try to view avaialable wireless again by ff the steps above.
{ tthis will refresh your wireless network hardware and software}
Note: for yellow exclamation marks or questions marks on your wireless adapter you MUST reinstall your DEll Wireless adapter. using you DELL System Recovery Disk.
In most instance it has somthing to do with your wireless switch on your laptop. With all possible steps porvided above doesnt woprk pls notify me. Thanks and good luck.
Jun 11, 2008 | Dell Latitude D600 Notebook
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Setup for wireless internet
go start/control panel /wireless assistant configure it there !
make shure to askyour husband if is cryption for router is wep or wap it makes a difference there but first configure it in the control panel!
Jan 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba laptop wont find router
Right click on the network icon in your task bar or in network connections in control panel and click view wireless networks, then when all the networks show, delete them all and close the window, next, a pop up will say found wireless connections click the pop up icon again and look for your connection in the list and click connect and enter the pass phrase Iif you have security enabled.
Nov 06, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
Canon Printer CUSTOMER service pHoNe{-l855*22l~4867}nUmBeR California USA Canon Printer CUSTOMER service Number +l85522l4867}}USALogin Repair service center to resolve all Canon Printer tEcH SupPoRt pHoNe nUmBeR products. Canon Printer ROUTER is an American multinational company which was founded by Michael Canon Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Canon Printer ROUTER support number, and selling of computer-related services and products. Canon Printer ROUTER Tech Support Phone Number Recently, Canon Printer ROUTER has been named the number Canon Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Canon Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Canon Printer ROUTER Service Tag or a Canon Printer ROUTER Get Canon Printer ROUTER Technical Support Phone Number and Customer Services. Canon Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Canon Computers & Internet
Computers & Internet Logo
380 people viewed this question
Ekse
Marvin
Marvin
