If you installed a new hard drive.. did you also installed windows on that new hd? if you did.. you may need to also install the sound card drivers.
the sound from your speakers depend on the sound card on your computer, and the sound card works only if you install the drivers that are specific for that sound card/computer. if you need help finding the drivers post back you computer specs (model, brand etc) and operating system and we'll help you find the drivers that may need to be reinstalled.
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
hope this helps you
