TV / DVD Recorder HDMI issue
I have bought a LG DR289H DVD Recorder and its apparently HDMI upscaling. I have a Samsung 48 inch Plasma HD Ready TV. I have bought the High Def cable and thought that putting the cable in the only High Def slot on the back of each item would be the simple solution to getting the High Def part of this link up to work. I was wrong. The TV says something along the lines of "HDMI not recognised". Someone mentioned that I would have to change the setting on the DVD Recorder to HDMI but I have no idea where that setting is or if this is what I'm meant to do. Can you please advise?
Thank you.
  • 108 Answers
By default most HDMI DVD players are set to produce their picture output on the Scart connection. This allows configuration of the device on all TVs.
However your manual should tell you (Probably in techno speak) what you need to do so switch it to HDMI mode.
I don;t have a copy but I am searching for it on the net. If I find out how I will let you know.
Posted on Mar 13, 2008
SOURCE:
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
Samsung 63 inch plasma sound no picture
This problem isn't a capacitor issue .Its a Y-sus issue or a panel issue
you need advanced help to solve this .
Jun 24, 2014 | LG RU-42PX10 42 in. HD-Ready Plasma...
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Hi ive been offered a techwood twp4210 plasma tv and i have a couple of questions can you advise if this is hd ready also how old are they, have also been advised that on start up it shows green sparkles...
The unit was being manufactured in the early to mid 2000's but I believe is not out of production. It is NOT an HDV. Here are the specs for the TV.
Product details Manufacturer Techwood Built-in Sat-Tuner No Compact Flash Card No Digital Tuner without Digital Tuner DVD Player / Recorder No HDTV Norm No Loudspeakers without Loudspeakers Memory Stick No Multi Channel Receiver without Multi Channel Receiver Type No Multimedia Card No PCMCIA Interface No Common Interface Slot No DVB-C No DVB-S No Screen Format 16:9 Screen Size in cm 106 cm DVI Interface No Electronic Program Guide (EPG) No Screen Size in Inches 42 in Secure Digital Card No Energy Savings Trust Feature No HD Tuner No Smart Media Card No Type of Monitor Plasma Display, Plasma Horizontal Resolution in Pixel 852 PC Interface No Vertical Resolution in Pixel 480 Brightness in Candela/m² 650 HDMI Interface without HDMI Full HD without Full HD (1080p) DVB-T without Digital Tuner HD ready Not HD Ready LED Backlight without LED Backlight DLNA certified No Energy Saving Trust Feature No HDMI No HDTV No Internet Access NO WEB CONTENT ACCESS EAN 5017416142205, 5017416183666
Nov 19, 2009 | Televison & Video
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I just bought a 50" LG tv plasma and its supposed to be a 720....
Well it depends on what your watching on the tv. If you hook up an HDMI cable with a dvd player or other accessory, such as HD cable box on an HD channel it will swap to 720p.
Aug 04, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
I WANT TO SET UP HDMI FROM LG RECORDER TO SAMSUNG PS42C91HD PLASM
I think if you look in the instruction manual under faults,it say the cable must be a certain value ie 1.3,it should tell you on the package.I hope this is of some help
Jul 18, 2009 | Televison & Video
Wharfedale DS-A243 HDMI Upscaler wont play HD DVD
Hi, sorry to have break it to you but your self diagnosis was correct! It is a 'normal' DVD player that upscales and will NOT play HD discs.
Nov 12, 2008 | Wharfedale DVD-M3 DVD Player
Hook up
The Pro 1000HDI has 1 HDMI input while the pro1000HD does not. Get a good set of component cables and that will upscale to 1080I you'll be fine
Aug 11, 2008 | Pioneer PureVision Pro-1000HD 50 in....
We have a wharfedale dvdr24hdmi player recorder but the hddvd we have purchased will not play.A note inside the dvd disc suggests we consult yourselves for a firmware or software update.
The wharfedale dvdr24 is an upscaling dvd player and not a hd dvd player which is why it wont recognise the disc you are trying to play.
HDMI just means that it connects to your tv via an hdmi cable, so unfortunatley you'll need to buy a hd dvd player to play your disc.
Apr 19, 2008 | Wharfedale Televison & Video
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Ekse
