Trouble with my canon copier ir 2870
I have trouble with my canon copier ir 2890
It only diplay the code number E 000602 - 0113
Can you help?
  • Anonymous Sep 09, 2008
    i have trouble with my canon ir 2870
    it only diply the code number E 000019-0000
  • Anonymous Mar 20, 2014
    Location of the print meter to find out how many copies we have printed?
  • 1,326 Answers
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
Posted on Mar 16, 2008
    Problem Solver:
  • 10 Answers
you can chang the hard disck for the copier
Posted on May 02, 2009
I have trouble with my canon copier ir 1150
it is copying but not printing through computer
From Srinivasa Reddy
Posted on Sep 18, 2008
2870 canon copier machine showing error code E000024-0001
service manuals free at may help you out .
Jul 03, 2015 | Canon IR 2870 Digital Copier RECONDITIONED
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
I need help in canon ir 2870 error 00001
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
NOTE: if the fixing unit circuitry has an open or a short, the code may not reset.
Confirm the fixing unit wiring and try to reset the code first, before you replace the Main Power Supply Assembly
hope it helps
Sep 24, 2012 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Sep 09, 2008 | Canon imageRUNNER C3200 Copier
768 people viewed this question
