Computers & Internet Logo
Posted on Mar 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AMD sempron power supply
Computer had power supply board failure put in new power supply an nothing will load upon start up just shows winfast on monitor.
  • 1 more comment
  • Petra65 Mar 16, 2008
    Information:
    Mother Board
    ZIP CODE WYWE 50801705 pc 760M01-GX-GLRS
    Winfast * K85755M
    * K85760MG
    760GXK8MB
    Machine: AMP SEMPRon Q Max Series 1
    After trying to reset we now have no screen the computer wants to keep running and there are three short beeps when pressing the on/off button. Also when pressing the reset button there is one continous beep for a 2 seconds.
    Hey we now have a screen we have error msg.
    CMOS checksum error - defaults loaded
    Press F1 to continue, Del to enter Setup.
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Mar 16, 2008
Anonymous
Expert
Level 2:
Answers
50
Questions
Helped
52152
Points
127
Are you using a WinFast series motherboard? What exactly does the screen say on it? Do you hear any beep sounds from the system speaker (the one on the board, or connected through a jumper, not external speakers connected through a plug)? The number and duration of each beep (short or long). If it uses an Award/Phoenix bios, here's some beep-code troubleshooting info:
XXXXXXXXXX 1 Long, then 2 Short Beeps: Video error XXXXXXXXXX
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
Recommendation:
* Troubleshoot the video card.
* If the video card is not at fault, troubleshoot the motherboard.
XXXXXXXXXX 1 Long, then 3 Short Beeps: Video error XXXXXXXXXX
Recommendation:
XXXXXXX Continuous Beeping: Memory or video problem XXXXXXXXXX
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
Recommendation:
* Troubleshoot the system memory.
* Troubleshoot the motherboard.
XXXXXXXX Other Beep Codes XXXXXXXXXXXXXXX
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
Recommendation:
* If you have recently flashed the system BIOS on this machine and corrupted the BIOS, and the system supports the boot block feature, the beeps may be codes communicating the status of the system as it tries to recover from the failed flash procedure. This is especially likely if the floppy drive is accessed very early in the boot process.
* Contact the vendor of the system or motherboard. They often have more specific information on beep codes.
* Troubleshoot as an apparent memory problem.
* Troubleshoot as an apparent motherboard problem.
I also found that 5 short beeps repeated can mean the primary bios has faled and it is using the secondary bios on board that have backup bios.
  • Anonymous Mar 16, 2008
    another possibility is that you have replaced it with an insufficient power supply. What mainboard are you using, how big of a power supply, and how much additional hardware do you have connected to it?
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3088604
Points
19604
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
  • 1 more comment
    Hi again,
    Appreciate your quick response. Winfast has been taken over by Foxconn so most information are rather hard to get.
    However, I would suggest that:
    1. reset your CMOS/BIOS using the blue jumper and temporarily moving the blue jumper to the other pair and then back to original position;
    2. check that your memory are OK and seated properly. It may need some cleaning by using a pencil eraser on the little gold pins;
    3. remove all other connections to the power supply such as your HD and CD;
    4. run the system at bare minimum and slowly, one at a time re-connect all other devices until such time everything is connected/operational or when problem re-surface. You would have then isolated your problem.
    Please update any developments (or lack thereof).
    Cheers.
    Your board looks something like this?
    Press Del to enter into the CMOS configuration, select "Load Fail-Safe Defaults", "Y" for yes,, Select "Save and Exit Set-up.
    or
    F1 to continue as is.
    Either will work except for the date/time settings.
    Since you have reached that far, that is indicative that chances are the system will now work.
    If it detects your hard disk, then your good to go.
1helpful
Sir i have amd sempron processor tm-1200 & i have dual os xp & linux as so many problem were found (hang,dump,disk failure) plz do suggestion need full.........{this is support linux?}
I take it you are getting panic traps, this happens when the kernel gets unstable with linux. Solution is one or two things, it could be generated from either drive failure or system board problems. From the root # type in dmesg and it may show you the error messages. Post the message and I may be able to help you further.
5helpful
I have a Winfast K7S, 741M01C, series motherboard
Hello Friend,
The max RAM that you can use with this motherboard which has 2 RAM slots is 2GB.
Best Regards,
Graphics card problem?
You are pushing the hardware you have. Is your board, processor, power supply ample enough? It is best to check running processes and programs to see if you are spiking your systems ability to perform.
2answers
Currently has 2600+sempron at 1.6ghz, want to upgrade processor, what is the maximum this board will take
His Motherboard is a Foxconn/Winfast 760GXK8MC-S , which rather annoyingly is not listed on foxconns support site so im thinking its an oem motherboard
Some quick googling shows:
AMD Athlon 64, AMD Sempron With FSB 1600mhz
Sorry that i cant be of any further help ,
If you found this useful , please rate my solution below
Kind Regards
1234s282
Amd sempron
Make sure you go into the bios settings of your motherboard and shut off the on board VGA. You will need to plug the monitor into the onboard VGA adaptor before proceeding to use the secondary adaptor.
My computer shuts down when i play or when i exit 3d games
Hi, has the problem recently started after the installation of sp3 because it has been known to cause problems like your having. If the computer is a new build it could be one of two problem, the asrock motherboard which i personally wont use anymore because of constant failure, or your power supply is not powerful enough. i would recommend nothing less than 500w power supply for gaming pc`s.
Hope this helps,
2answers
Winfast 760GXK8MC 754 SEMPRON aTHLON 64 pROCESSORS
disconnect all external devices and then bypass the UPS and plug the power cables, monitor and computer, into wall socket outlets. Make sure and disconnect any ethernet cable as well.
2answers
Asrock k7s41gx
it seems to me its a dust problem. any beeps?
Grand Canyon Tech
Grand Canyon Tech
