No input signal form a laptop to a projector
I can not set my Emachine latops to work with my projectors. The message is no input signal
  • Anonymous Mar 05, 2009
    I hvae a mitsubishi s120 no signal..I need help..i have a prsentation tomorrow help
    Scholar:
  • 64 Answers
Hi jkoceng,
What type of interface cable are you using to connect to the projector? 15-pin VGA? S-video?
Generally on laptops if you look at the keyboard on the function keys (F1, F2, etc.) you'll see little icons such as adjustment of volume, brightness, etc. Look for one that looks like a monitor or screen. Usually this is on the F5 or F6 key. If the icon is blue, look for the corresponding key on the keyboard (Fn key, CTRL, Alt, etc.) and then hold that when connected to the projector while you press the appropriate function key. This should alleviate your problem.
Of course, you'll also want to be certain that you're using the correct input function on the projector.
Ben
Posted on Mar 13, 2008
Why is my Sharp PG-D2510X Projector keep saying that there is no signal? It worked up until yesterday.
Check both input selections on your computer and your projector. They both need to be set on the same input to work. For example, if the computer is set at 1080 and the projector is set on 720, it wont work. They need to match. Good luck!
Apr 13, 2016 | Sharp PG-D2510X DLP Notevision Multimedia...
No image! My input signal is recognized, but nothing will display.
check laptop output settings my laptop uses f4 with the function key to switch the output mode your laptop may have a similar setting from Laptop only to Dual Screen to Composite screens.
Jul 08, 2015 | Christie RoadRunner L6 Multimedia...
I follow the set up proceedure to connect the projector to my acer laptop. I then switch on power to the projector and boot the laptop. After the 30 second count-down I et a no signal message which stays...
Not wishing to show Grandmother how to **** eggs, but there are three VGA sockets. One of them is VGA out.
Can you select the inputs on the menu system?
Hope that helps.
Feb 23, 2011 | Sanyo PLC XU30 Multimedia Projector
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
Message
Reduce the screen resolution to 600x480 for instance and see if the projector can handle the low res output OK. Then increase screen resolution on the PC unitl the error message appears. Try the video menu settings in the acer
Jul 17, 2010 | Acer X1230 DLP Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Hp vp 6210
connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Mar 28, 2008 | HP VP 6210 Multimedia Projector
Toshiba TDP S8
First make sure your signal cable is ok and well connected.
Next check the projector input settings in the menu, and confirm that you have the correct input selected.
Also make sure your Laptop display settings allow for an external monitor.
Baba Anji
Dec 30, 2007 | Toshiba TDP-S8 Multimedia Projector
Projector not recieving input signal
eeek matt. an ally olly, (means garlic mayo in spanish)
never mind, i'll try to help.
first check out all signal in options, are you sure pj is receiving a signal in. use all available input option to check out.
if no joy proceed carefully as follows
power down,openup pj and check by inputs pcb panel.
probably a mini plug has fallen out or a slidein flat cable is not fully plugged in
good luck with the faultfinding
Dec 16, 2007 | Office Equipment & Supplies
LCD projector no signal message
you may need to go into display setting and check that these setting match the ones for the projector
Nov 27, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
338 people viewed this question
David Payne
David Payne
