Question about Candy CN146 Front Load Washer
Candy cm1126 fills with water when turned off, sometimes overfills during wash
    President:
  • Candy Master
  • 2,651 Answers
Although not famillar with your particular model. if its filling with water when not even turned on you have a bad water inlet valve.no servicing just replace
Posted on Mar 13, 2008
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
My Whirlpool AWG5122 washing machine keeps overfilling, it seems to take in water to the point of overflowing, I have to turn the water off at the mains in order for it to stop taking water in.
sometimes if the door switch of that machine is not working so there is no auto stop of filling water. or the pressure switch may be not function well.
Dec 09, 2010 | Whirlpool AWG5122 Front Load Washer
Water is all over the floor from the washing machine. What could be the problem
water pump, hose or tub.. depends when you noticed water. After it was filled? during draining or filling? Also a clogged drain will cause backwash. Holes in tub from rust will leak out water, water pump cracked can leak water or hoses to drain or to washer not sealed or cracked. Overfill from a faulty fill valve can also do that, but then you'd see lots of water all obver on that one.
Jun 16, 2010 | LG WM1814CW Front Load Washer
? Overfills. Doesn't seem to acknowledge water
put the washer on fill,now turn it off,if the water stills fills it is a bad inlet water valve,if it does not the water level hose might have come off or the water level switch is bad,let me know what you find-mike
Apr 04, 2009 | Kenmore Washing Machines
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine overfilling
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Sep 29, 2008 | Washing Machines
Our washing machine keeps filling with water and overflows. It will not stop filling with water no matter what setting it is on.
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Apr 26, 2008 | Washing Machines
Candy CN146 Front Load Washer Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
